some freetv through Sky Dish and LNB
kalli
Hey,
if I disconnect my Sky Q box (2 sat cables, all working, subscribed) and connect either of them to a hauppauge DVB-S2 and scan for channels, should I get to see any channels (dont care if free/encrypted). its just for a test.
background: my father uses linux only, but has to use windows only for watching Sattelite TV (not sky), i found a dongle that seems to work under linux, but when I use sky q cable and scan I cannot find anything.
I have a feeling the problem is rather that I'm testing with Sky dish, sattelite and LNB rather than the device
I dont want to move satellite dish or buy a new one for test. I just want to test if it can work in principle and send it to him
thanks for any help here. if consensus is: doesn't wqork with sky i can send it to him as otherwise all ok.
but if I should see channels (some encrypted, some free, etc) then I know something is wrong
Hauppaauge WinTV-NOVA-S2 Freesat DVB-S2 Satellite USB Receiver
Fred Smith
You need to change the LNB to a Sky Hybrid LNB, a Sky Q LNB is not suitable.
There are many posts on on the forum about this.
chenks
no, the LNB you will have is not compatible with your non-sky box.
kalli
Hey guys - thx for that. I actually did google and search for the forum.
I'm not sure how I overlooked it.
logiciel
Good you found the forum!
