Some folders will not delete - Already uninsialled program using it
Discussion in 'Computer Components' started by Frazal666, Jul 1, 2005.
  1. Frazal666
    Frazal666
    Hi everyone,
    I have a problem. Three programs that I have uninstalled, all the files are deleted. But thier folders, when I try to delete them, they all say
    'cannot delete program: It is being used by another person or program
    close any programs that might be using the file and try again'
    I have closed every single program (execpt the system ones of corse) and it still doesn't work. I have tried going into safe mode and deleting them, but they reappear after I restart. I have used a very highly rated registry cleaner, it's still there.
    I am running windows xp, these files are in 'program files', and the folders are: microsoft frontpage, movie maker & msn gaming zone. msn gaming zone has 'windows' , which is empty, frontpage has 'version 3.0' which is empty. movie maker is just plain empty.
    the folders in the folders say the same error message.
  2. lisag
    lisag
    Jul 14, 2004
    5,696
    Essex
    +336
    Try opening a cmd prompt, closing explorer.exe and then deleting in the cmd prompt - may not work, but does sometimes.
    lisa
  3. mrmoo
    mrmoo
    Jan 10, 2005
    515
    +20
    Have you checked for any hidden system files? Check the options under
    my computer>tools>folder options>view
  4. Frazal666
    Frazal666
    neither works. Oh well, not a big deal, doesn't really matter.
    thanks anyway
