Some connection help please?
Discussion in 'Plasma TVs' started by shand754, Jul 2, 2005.
  1. shand754
    shand754
    Jul 2, 2005
    1,485
    48
    +99
    First post so be gentle with me please!
    I have had a Panny 37" PV500 for about a month now, very pleased with it but I have a connection problem I could use some advice on.
    I currently have a DVD recorder (with Q link) hooked up to the plasma by S-Video and a Skybox hooked up by RGB scart.
    My problem is I cannot get the DVD recorder to pick up the Freeview on the plasma so I cannot record from it.
    I am guessing my problem is that I need to use scart from the DVD recorder to one of the AV sockets that supports Q link on the plasma.
    Can anyone confirm this and has anyone successfully recorded from the plasma freeview onto a video, DVD recorder?
    Thanks in advance for any help.
  2. shand754
    shand754
    Jul 2, 2005
    1,485
    48
    +99
    Anyone?
  3. shand754
    shand754
    Jul 2, 2005
    1,485
    48
    +99
    Could really do with some help with this. Has anyone linked the PV500 to a VCR or DVD recorder and managed to record from the freeview?
  4. Enquirer
    Enquirer
    Right i don't own one and have never used one but i'll try to have a stab at it and if i get it wrong there is bound to be some clever dick to tell me i am wrong :D
    On page 8 of your manual it says
    Notes:
    • If using a “Q-Link” VCR / DVD Recorder, then the AV1 Scart of the VCR / DVD Recorder must be connected to the
    AV2 or AV4 terminal of the TV. If your VCR or DVD Recorder is not a “Q-Link” device, please consult the operating
    instruction book for that product. Further information on Q-Link can be found on page 34.
    Then on page 15
    AV2 / AV4 out Offers a choice of signals to send to the Scart terminal
    selected in the Q-Link option. You can choose from the
    current TV (Analogue, DVB) programme position, the signal
    entering AV1 / AV2 / AV3 / AV4 or Monitor - the picture
    displayed on screen.
    Component signal input cannot be output to these Scart
    terminals.
    So it seems to record from your tv freeview programmes to an external source it suggests you plug in a fully wired scart lead into AV2 or AV4
    Then you should be able to use the direct TV rec function,the Recording device Auto Power Standby function and the Recording device Image View On function :confused:
    Thats what the manual suggests BUT often there are other ways of wiring it up for better PQ lets hope some owners post a few suggestions.
  5. shand754
    shand754
    Jul 2, 2005
    1,485
    48
    +99
    Thanks, that pretty much confirms what I had guessed. I shall give this a go.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    seems its all under control Shand
  7. shand754
    shand754
    Jul 2, 2005
    1,485
    48
    +99
    Thanks guys, I need to pick up another RGB scart lead to try this but it sounds like this should solve it for me.
  8. dodgydaz
    dodgydaz
    May 17, 2005
    411
    Nottingham
    +10
    I had my dvd recorder connected via component so didnt set it up with Q link. Then after I read your post, I realised that if I wanted to record from freeview, I couldnt do it.
    Now I have sky + so always use that anyway but it bugged me that there was a facility on my TV/dvd that I couldnt use. So I connected a scart to AV2 on the TV and downloaded the tuning settings to the dvd. Now I can just press the direct record button and am able to record from freeview.
    Probably never, ever use it, but its all set up if I want to. :D
  9. shand754
    shand754
    Jul 2, 2005
    1,485
    48
    +99
    Good to know it works mate. When you say you downloaded the tuning settings to your DVD do you mean that you ran auto setup on the DVD recorder?
  10. dodgydaz
    dodgydaz
    May 17, 2005
    411
    Nottingham
    +10
    Hi Shand. I got the ES10 dvd recorder with my pv500 and in the tuning menu you can select Auto Setup or below that is "Download from TV". I chose that option and it tuned itself in to the tv channels in about 30 seconds. Quite impressed.
    I am thinking of probably getting rid of sky+ in a few months as I am spending £35 just for the priviledge of being able to record a program with the press of a single button. Plus it is very wife friendly.
    But with freeview, you have the programme guide which is similar to sky, and the option of setting up a recording from that. Not quite as advanced but if it saves me money!!
  11. shand754
    shand754
    Jul 2, 2005
    1,485
    48
    +99
    Cool, so does it tune in to the analogue channels as well as the freeview or is it one or the other?
  12. dodgydaz
    dodgydaz
    May 17, 2005
    411
    Nottingham
    +10
    It tuned in everything mate.
    Basically, if I select AV1 on the dvd, it shows either freeview or analogue, depending on what mode I have selected on the tv.
    If I select AV2, then that shows sky +.
    Then the other programmes- 1,2 3 etc are analogue.
    So I can record any channel from any source.
    Hope this makes sense :)
  13. shand754
    shand754
    Jul 2, 2005
    1,485
    48
    +99
    It does mate, thanks for all the info today - it has really helped.
