Some basic questions
Discussion in 'Plasma TVs Forum' started by Bigmonty69, Jan 16, 2004.
  1. Bigmonty69
    Bigmonty69
    Jan 7, 2004
    826
    +73
    Read through these forums quite a bit and seen a few conflicting posts about the set up of a PW6 Panny. So I am looking for some simple answers to help me get started.
    I have just bought the Panny and also have a Jamo Dvr50, video recorder and freeview box.
    What I would like to know is how to connect them to achieve the best possible picture results. The Panny comes with only a scart terminal board installed and the VGA input that is standard I believe.
    I relealise I can connect the Jamo via Component but I am confused as to whether I should be purchasing a component terminal board for slot 2 or 3 (£110ish) and connecting direct to this or, as I have read elsewhere, connect it to the VGA slot??
    Also I am totally confused as to how to connect the Freeview box and Video recoder to it, seening as I have only 1 scart board on the back. Do I need to purchase another scart board or should I purchase a Switch box, if so which one as I have no idea which is the best?
    Please help.
    Cheers.
