Some Basic advice please..!
Discussion in 'AV Receivers & Amplifiers' started by fabio1605, Jun 24, 2004.
  1. fabio1605
    fabio1605
    Hello im quite new to the seperates business and i am considering purchasing a new system...
    Now what are your views on this system... im looking mainly for the system to produce a high amount of sound and good quality... not as such as the surround sounds, or cinema sound etc.. and also what does the total purity mean... it can produce 6 x 85 now i dont know if thats amazingly loud or not.. so any advice you give me would be much apreciated
    http://www.empiredirect.co.uk/productdetails/index.asp?modelcode=YAM-DSPAX640SE&clear=
    Also which speakers would suit the amp more
    http://www.empiredirect.co.uk/productdetails/index.asp?modelcode=WHA-D82B&clear=
    again any advice apreciated,thank you very much
  2. mevetts
    mevetts
    Oct 31, 2003
    439
  3. fabio1605
    fabio1605
    heya,thanx for the reply.. welll i kno that amp is good for value.. can cost up to 350 in some other shops... but im still confused to weather it has good power??? or is good for value im more concerened about the amount of sound it produce... that thread is a lil confusing for me
    By the way you know you said the mission speakers were both good... would they be suitable for the amp???
  4. fabio1605
    fabio1605
    oh and do you not think the warfdale speakers match the amp?
  5. fabio1605
    fabio1605
    wow...! them mission speakers are a bit out my range to be onest! 170 quid a pair
  6. Dfour
    Dfour
    Jan 19, 2004
    4,007
    71
    Bracknell
    +86
    OK im a little confused as to what exactly your after here. A multi channel amp and just a pair of front speakers? What are you going to use them for, stereoor multi channel? How much is your budget?
  7. fabio1605
    fabio1605
    rite... i want multi channel... i want a hight sound output after all im only gonna use it to listen to music on not for surround sounds and i just thought that if i used all 6 channels id get a higher output of sounds... or is that wrong..?
  8. fabio1605
    fabio1605
    my budget is about 400 quid .maybe 500 for an amp and speakers
  9. Dfour
    Dfour
    Jan 19, 2004
    4,007
    71
    Bracknell
    +86
    If all you want is stereo you will get a much better sound from a stereo amp than from an av amp. If you really want to get an av amp for stereo you will have to spend £500+ to get anything that will produce sounds like a £300 stereo amp.
    How about:
    http://www.richersounds.com/index.php?f=itemdetl.php&p=301604
    http://www.richersounds.com/index.php?f=itemdetl.php&p=101443
    http://uk.pricerunner.com/sound-and-vision/sound/speakers/167435/details
    Also make sure you use a CD player to play music dont be tempted to use a cheap dvd player:eek:
  10. fabio1605
    fabio1605
    the speakers look good,but there 100 watts and the amp can only produce 65 a channel? how many channels does ths amp have it doesnt say? so are you saying also that av amp wont be as good as the 260 stereo amp u showed me...
    Just that amp dont seem that powerful or is that just me becuase im not so sure about these things
  11. Dfour
    Dfour
    Jan 19, 2004
    4,007
    71
    Bracknell
    +86
    I wouldnt worry about the amp rating of amps and speakers that much. There are a few threads on here about it than can explain it much better than i can so do a search on watts or just go and have a look back.
    For stereo the 2 channel amp will blow away most £500 or less multichannel amps in stereo The amp rating on speakers is a guide as to how much power they can take before distorting (i think) and most of the time most people wont be driving them anywhere near that hard. I have the evo's and they make superb stereo speakers with loadsa power and bass:devil:
    What other hifi kit do you own at the moment Fabio?? Also dont forget you need money for good interconnects and speaker cable. Mark Grant does some .5 and 1 metre long quality stereo interconnects for £25 :smashin:
  12. fabio1605
    fabio1605
    att he moment i have a stand hifi. not a seperates. it proudecse 200rms which is good.. but i want more... the speakers say 16 impedance 100 peak on the back.... would they also be handy to put in aswel do you think??? Could you recomend any other stereo amps about for about 200 quid around.
    But im after massive amounds of sound and that amp looks like 2 channel 60 so its only producing 120.. my hifi now does that 200... thats y im really confused
  13. fabio1605
    fabio1605
    sorry if im being a pain... i just want to make sure i get good value... but i dont understand y i would be better getting a 2 channel stereo amp that makes 120 in total than 5 a channel 100 watt amp when theres abotu 300 watts diffrence...
  14. fabio1605
    fabio1605
    just looking throught the forums... cant find owt about voltage... and ive noticed ppl link there stereo amps to receiver amps.. what does that gain.... hmm and a 120wat stereo amp.... how loud is it.... my rooms only 4m x 4m only for personal use... but is it something you could classify as extremly loud!
  15. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    Watts don't necessarily = power. It's just a nice marketing myth to get people to buy midi systems with a multitude of flashing lights and loads of drivers in the speakers.
    Go and do some searching on older topics for a more thorough discussion - it's been done to death before.
    You'll find most people around these forums are more interested in sound quality, not SPL.
  16. fabio1605
    fabio1605
    hmm, well thanx to you all your help i think ive narrowed it down to this amp.. can i just ask for your last oppinouns on this systme please
    either
    http://www.empiredirect.co.uk/productdetails/index.asp?modelcode=SON-TAFB940R&clear=
    or
    http://www.empiredirect.co.uk/productdetails/index.asp?modelcode=MAR-PM7200G&clear=
    http://www.empiredirect.co.uk/productdetails/index.asp?modelcode=WHA-D82BEE&clear=
    or would i be better spending more money on the speakers??? because ive heard that its the speakers that make the sound better than the amp
  17. Dfour
    Dfour
    Jan 19, 2004
    4,007
    71
    Bracknell
    +86
