Some advice please
Discussion in 'Plasma TVs' started by petrolhead, Jan 17, 2004.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    I bought a 37 panny from Comet.
    It came with a 1 year guarantee.
    They are now offering an additinal 3 years for £300 which isn't too bad.
    What do you think?
    Should I go for it?
  2. bobbypunk
    bobbypunk
    check what it covers, can comet repair plasma's or do you have to wait for panny engineers to look at it, do you get a loan set (Even a CRT?) and does it cover accidental damage.
    Check cause the price sounds reasonable.
    (I'd expect engineer call outs and loan set at least)
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    Here is whats covered:
    Cost of repair inc parts and labour
    Accidental damage (Pysical damage as a result of unforseen circumstances)
    If unable to repair replacement given. New for old
    Once a replacement made policy will end immediately, but I may dispose of said equipment as I see fit.
    They refer to my plasma as a television. (I have written to them comfirming this)
    The plan is underwritten by Domestic and General
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,346
    Windsor
    +1,028
    you could try contacting domestic and general directly, to see if they are cheaper.
    link
    I tried putting in your screen, but it wouldn't give me a quote, so you'll probably have to give them a ring.
    Also worth finding out whether your home contents cover gives you accidental damage protection, and how much an engineer call out is worth?
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    You must be snooping on my PC as I have just sent them an email
  6. chriswynn
    chriswynn
    how good is your plasma as i am thinking about swapping my phillips 42" for your model and how much did you pay?
  7. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    Hi Jason
    The first link quotes £450+ for extra 2 years
    The second £199 for extra 2 years which works out £100 per year but don't seem to offer 3 years extra
    Peter
  9. richard plumb
    richard plumb
    Jan 27, 2002
    14,346
    Windsor
    +1,028
    you should also check what comet are offering. Usually their 3 and 5 year warranties are actually 1+2 and 1+4, so you are only getting an extra 2 years anyway?
  10. petrolhead
    petrolhead
    Mar 29, 2002
    4,484
    71
    Newcastle
    +82
    Theres is an extra 3 yrs
