Some advice please. DVD Recorder
hansi
I have a very cheap DVD Player which is on its last legs, so to speak, and I want to replace it with a recorder. My present equipment is a Pansonic 26" HD TV which is connected to a Virgin Media V+ Box by HDMI lead which can receive HD channels. What I would like to do is to transfer some of the recordings on the Virgin hard drive to a DVD disk , but can I do this via HDMI? There is only one HDMI outlet on the TV. Otherwise I guess it will have to be by scart lead. Your susggestion for a DVD recorder would be appreciated:lease: as I haven't a clue. It's a jungle out there!
Geofbob
No you can't record via HDMI - because no recorder has an HDMI input (to prevent HD copying for copyright reasons). But the outputs on the TV are irrelevant - you'll be recording direct from the V+ box via Scart.
The usual recommendation from AVF is that you should not go for a simple DVD recorder, but for one with a hard disc, ie a DVD/HDD recorder. Sony & Panasonic models are (not surprisingly) the most versatile & reliable, with perhaps the Pannies taking precedence.
hansi
Thank you for your input. I'll probably go for the Pannie as I've already got the Pannie TV, is anyone better that another, and should I be looking for any particular features. Another requirement is that is has to be thin to fit under my V+ Box!
Gavtech
Administrator
Panasonic EX769... 59 mm high
Details here.
This is a very good all round recorder.
If you want bigger hard disc and USB support go for the EX79
If you want even bigger hard disc and SD card support EX89
hansi
I don't actually want the Freeview as I've got the V+ Box and I've got Freeview built in to my telly. But I guess that you can't get them without Freeview?
Gavtech
Administrator
No.
Having freeview integrated can be helpful as it allows you to record something from freeview whilst watching something else from V+
hansi
PANASONIC - DMRXS350EBK - High Definition DVD Recorder with HDD (250GB), Twin HD Satellite Tuner, SD Memory Card Slot and USB
Saw this the other day. I know it's quite expensive, but what are the advantages of this over the other Panasonic models suggested. Sorry, I'm a bit of a thickie where technology is concerned:eek:
ramjet
it uses two tuners connected to a satellite dish pointed at astra 2, and so gives you freesat channels
it also means you could record one channel and watch another channel , and is independent of your v+ box
the usb and sd cards can be used for pictures and mp3 and anything else panny allow , so they have the slots for them on the machine
it also produces high def so bbcHD and other HD channels that are free and similar to the bbcHD can be watched or recorded
so quite a lot of extras there providing you have a sky dish with a quad lnb and a twin shotgun cable coming from it ( typically used for sky plus , so its effectively freesat plus with added dvd capabilities )
hansi
Thank you for that. I don't have a satellite dish (I have a Virgin V+ box) so I guess that it's no good for me. Back to the drawing board, but would welcome any more suggestions.
ramjet
there is little on offer at the moment apart from what you see in this thread , so I would forget about the type of inbuilt tuner a machine has if you arent going to use it , and concentrate on the other facilities the units have
I would suggest you buy a freeview dvd/hdd recorder , usually with the freeview inbuilt tuner ( even if you dont wish to use it ) and connect it to your v+ box using a scart lead , and then do the tasks you asked about in post 1
personally I use the older sony models made by pioneer , but its the same principle regardless of using sky or virgin or any other cable or satellite box or tuner source
if you wanted something cheap , check for the sony hxd x70 , x90 and x95 models on e bay
but if you want something new and not involved with a dish , go for the panasonic ones suggested by gav
