Some advice on a suitable LCD
Discussion in 'LCD & LED LCD TVs Forum' started by zera, Sep 1, 2004.
Tags:
  1. zera
    zera
    Hi, ive been looking for hours on the net for a lcd that suits me but due to most sites not telling you all the features (especially not giving refresh rates). Now i know you must get this sort of question all the time but ive really tried to find some suitable tvs myself with no luck
    Im looking for an LCD thats 22-30 inch, with pc input and a very good refresh rate due to some gaming and i will really notice ghosting (im just like that), most likely widescreen but will consider standard size. I would also like it wall mountable.
    As low a price as possible but i know you get what you pay for so i dont expect anything really low definately under 1.5k but really under 1k please.
    Hopefull someone can point me towards some suitable tv's to look at,
    Many Thanks
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    The hitachi 28LD5200 is going for £1050 (ish) there was a thread on here a few days ago, try a search. Not sure if it has what you want
  3. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    Toshiba's WL46, 26" lcd is £1,200 from rgb, with pc input, 2 component, 3 scart, (2 RGB), and other svhs/composite connections. Good performance, great for games. Average looks though. Perhaps silver is starting to look dated!? Still, I have one and am happy with it. Has a screen res of 1366 by 768 which is the correct 16:9 as most lcd panels seem to be 15:9 or 1280 by 720. not only does the set accept 480p and 575p, (is that right). But also 720p and 1080i, (scaled down I suppose!?).
  4. Thrutch
    Thrutch
    Aug 30, 2004
    24
    According to Tosh's Website the 26LW46 it is 1280 X 768. There is no refresh rate. Are there any panels out yet that have a refresh rate less than 16 milliseconds ?
  5. Phybron
    Phybron
    I'm considering a Sharp LC-22AD1E, which has a 16ms refresh rate (I know because I emailed them to ask) and it has just dropped to £960 at http://www.digitaldirectuk.com. The older LC22SV2E is cheaper but has 25ms refresh rate.
  6. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    your getting 8 inches less for less then 100 quid over the hitachi
    :nono:
  7. zera
    zera
    cheers guys ill check out the models you mentioned, many thanks
  8. zera
    zera
    oh and i read while doing some research that they either just have or are just about to bring out 12ms panels
  9. Phybron
    Phybron
    Yes but I don't want a 28". This is supposed to be a second screen, not the main one for me.
    Am now looking at the 22" Hitachi though, which is only £614 - way cheaper than the Sharp. :)
  10. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    what about the philips 23pf9945? available for about £670, with PC input and proper hires panels. I've got the 30" version and its very good.
    I was looking at the sharp 22hv2, but it seems to only have 848x480 panels, so no use as a PC monitor (needed by me) - also no PC input :)
    Don't think there are any sub 16ms screens though. But bear in mind that most mainstream PC LCDs are 25ms, and 16 is a positive luxury.
    I'm off to take a look at that hitachi...
