Gnomeo
Update: It was my Panasonic BD player's VIERA Link setting that was breaking the ARC connection! I turned it off and now all is fine.
Hey everyone!
I have an annoying issue with my HW-Q800A soundbar, which I use together with a Q70R TV and a Blu-ray player.
Here is my setup: BD player to soundbar (HDMI to HDMI), soundbar to TV (HDMI ARC to HDMI ARC). When I hook everything up, it works as expected. I can switch back and forth between watching a BD disc and watching TV content, with the soundbar using either the sound from the HDMI or the HDMI ARC ports.
It works like that until I turn everything off. Next time I turn it all on, the HDMI ARC connection simply disappears, and sound from TV content no longer reaches the soundbar. It’s like there is no HDMI cable at all between the soundbar and the TV, it's even gone from the sound settings. The only way I can fix it is to (1) unhook the HDMI cable that comes from the BD player, and (2) unhook the HDMI ARC cable from both the soundbar and the TV and hook it in again. As long as no cable is plugged in the regular HDMI port of the soundbar, the ARC connection works fine.
To summarise: HDMI ARC connection only works fine; HDMI ARC + regular HDMI work until devices are restarted, after which the soundbar no longer sees the ARC connection.
I've already installed the latest firmware on all devices, I've reset them several times, and I've tried this setup with a different third device (a laptop). Nothing makes a difference.
Has anyone faced a similar issue? Thanks!
Hey everyone!
