Question [Solved] Openbox with a regular dish
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cmoidd, May 21, 2017.
Tags:
  1. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    I'm planning to get freeview. I currently have a regular dish. I'm looking for a cheap satellite receiver, which can record, I was thinking of getting an openbox, like that I can watch Netflix with it too.
    My question is can I get an openbox without a sky dish, with just a regular one.
    If not, what do you advice me to get?
  2. logiciel
    logiciel
    Feb 2, 2008
    53,098
    UK
    +5,758
    Hi and welcome to the forum.
    You'll be fine with any satellite receiver - Freeview is something else, of course!
  3. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,299
    Reading
    +407
    In that case you will need a Freeview box and an aerial.
  4. TJT1
    TJT1
    Jul 29, 2011
    4,658
    East Sussex, UK
    +1,089
    To explain the somewhat cryptic replies. Freeview is terrestrial TV. It's what you get on an aerial connected to pretty much any TV that isn't off the arc.
    The satellite service is Freesat (see what they are doing there). Freesat itself is only the EPG for the free to air satellite transmissions from 28.2E (mostly the same transmissions as on a Sky box with the exception of the Sky specific channels).
    You specified in your opening post the you wanted a sat receiver so it would be a Freesat box that you want?
    And you will be fine with your existing dish as long as it's aligned to the 28.2E sat group. If you can get Sky, you're home and dry. But I don't think and openbox is a Freesat box, so I don't think that you will not get the Freesat EPG, but I could be wrong as I often am.
  5. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,299
    Reading
    +407
    Correct Openbox / Skybox's are generic FTA receivers without the features like the Freesat EPG or channel sorting.
  6. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Thanks for your answer I live in Ireland so I need a dish to receive freeview
  7. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Thanks for all those details, so need a freesat box, then to get all the FTA channels
  8. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Some of the Openbox/Skybox stbs if connected to the internet are capable of downloading - mine downloads country specific EPGs rather than satellite specific and if I select England it downloads a 7 day EPG that covers most of the Freesat EPG channels and a few that are not on Freesat
  9. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Ok
    Ok, So if i understand, openbox would not work to get only the FTA channels from freesat?
  10. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    No you need a dish to receive FTA channels. In most parts of Ireland it is impossible to receive Freeview which is terrestrial TV requiring a UHF AERIAL
  11. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    That would be great!
  12. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Yes it's
    Yes it's what I thought
  13. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    It will get all the FTA channels including the just over 50% of them that pay to be on the Freesat EPG
  14. TJT1
    TJT1
    Jul 29, 2011
    4,658
    East Sussex, UK
    +1,089
    Yes it will. It's a generic satellite receiver. You can also get Freesat on 28.2E if you have a Freesat box. The channels on Freesat are just a bunch of the FTA programmes from the satellite but arranged in a nice 'standard' order such as putting BBC1 on ch 101, BBC2 on ch 102, ITV on ch103 etc. A FTA box does not necessarily sort them into the same order, but they are the same transmissions.
  15. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Ok thank you. I'll get the openbox then :)
  16. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Thanks for all the details, I'll go for the openbox then
    I'll be pointing the dish to Astra 28.2E, I'll also receive French TNT on Astra 19.2E, with the same dish
  17. TJT1
    TJT1
    Jul 29, 2011
    4,658
    East Sussex, UK
    +1,089
    Presumably by using two LNBs on a cross bracket or will you motor drive the dish?
  18. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Yes with 2 LNBs on a cross bracket, it is only 9 degrees so it should be ok
  19. TJT1
    TJT1
    Jul 29, 2011
    4,658
    East Sussex, UK
    +1,089
    Depends on the size of the dish. If it is a small dish, (say a Sky zone 1 as I have with three LNBs 28, 19, 13) then getting them close enough together for the 'only' 6 degrees of 19-13 that is the problem
  20. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Oh i never thought of that...
  21. TJT1
    TJT1
    Jul 29, 2011
    4,658
    East Sussex, UK
    +1,089
    You can get 28.2 and 19.2 on a zone one Sky dish with standard Sky LNBs, but they are just about touching. To get 19.2 and 13, you need slimline LNBs on a Sky dish. A zone 2 Sky dish would allow wider spacing, and possibly allow 19.2 and 13 with Sky LNBs, but I wouldn't bet money on it.
    Here's a pic of my Sky Z1 dish with 28.2, 19.2 and 13 LNBs, hidden nicely behind a bush that I have to keep well trimmed. DSC01135.JPG
  22. Adam792
    Adam792
    Sep 22, 2012
    33
    Worcester
    +16
    If this is in Ireland then the OP probably already uses a Zone 2 dish rather than a Zone 1 as they are installed as standard there.
    I have a Zone 2 with two LNBs on it (19.2°E and 13°E). They're both the standard Sky four output ones and they touch. The 13°E one is actually just cable tied onto the side of the 19.2°E one mounted in the centre of the dish. A bit of a bodge but it's fairly secure and seems to work well. To get 28.2°E as well you need to use some kind of bracket like in your post TJT1 as the spacing needs to be a bit wider rather than touching.
  23. TJT1
    TJT1
    Jul 29, 2011
    4,658
    East Sussex, UK
    +1,089
    Seems that OP has a "regular dish". Whatever that means.
    Sounds like you have been taking lessons from the master of bodge. Man after my own heart as perhaps you can tell by the use of LNBs designed for 'circular' dishes on an elliptical Sky dish. The purist would be aghast.
    Must get at mine with my fancy (read expensive) sat meter and see if I can tweak them a bit. I set them up originally with the 'catch all and beep' el -cheapo sat meter.
  24. Adam792
    Adam792
    Sep 22, 2012
    33
    Worcester
    +16
    Definitely! You never know until you try do you, and a few cable ties and a second Sky LNB only cost me a few quid.
  25. cmoidd
    cmoidd
    May 21, 2017
    11
    3
    Waterford, ireland
    Thanks everyone, I got my satellite dish installed and work preferctly with my open box. No problem to receive 19 and 28
