SOLVED - HDMI over cat5 problem
Discussion in 'Cables & Switches' started by stewy604, Apr 6, 2016.
Tags:
  1. stewy604
    stewy604
    Apr 5, 2016
    7
    4
    Vancouver
    Hey Guys,
    New member to avforums, not sure if this is the right forum to ask this, so here goes.
    I'm looking for some expertise and advise on a problem that has arisen on my home system. I've got my AV rack in the basement under the stairs, video is output to the Samsung panel mounted above my fireplace in the living room. The system was working flawlessly for 4 months and all of sudden I've lost the HDMI signal (regardless of source) to the TV. I've done some troubleshooting, including new HDMI cable swaps to chase the problem, firmware upgrades on all gear (including receiver), and hard resets / A/C plug pull, all to no avail. I've also tried re-ordering my power on sequence in the Harmony hub...no change. The only way I can get the video signal to work is to re-seat the HDMI cable that runs from my SC-85 receiver to the Aten balun mounted in my rack...this re-seat has to be done with the components powered on (which I've heard is a no-no since the HDMI cable carries a small DC current?). I'm forced to do this each and every time we power on the TV, once its on and 'connected', I can swap inputs without losing the video signal. Audio from the receiver is unaffected, and works fine. Any other ideas to help me here guys? I know HDMI / HDCP can be finicky at times....just frustrating that it was working 100% and now it's not, with no changes made. Let me know if you need any more information to help me. Thanks guys!
    Hardware Snapshot:
    Pioneer Elite SC-85 AVR
    Arris HD Set Top Box
    Arris HD Gateway/PVR
    Sony BDP-S550 BD Player
    Harmony Home Ultimate Hub
    Aten VE-800A HDMI Extender Kit
    RTI IR Kit
    Samsung UN65JS8500 Panel
    Apple TV (Gen 4)
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Try and narrow down the culprit
    Does the Aten extender work when the AVr is taken out of the equation ?
  3. stewy604
    stewy604
    Apr 5, 2016
    7
    4
    Vancouver
    I haven't tried that yet, but good idea. I'll do some more troubleshooting this week/weekend and report back. Such a pain to chase these issues...but hey, that's technology right?
  4. HDC James
    HDC James
    Active Member AVForums Sponsor
    Nov 3, 2008
    1,502
    Malvern
    +240
    How old are your A-ten extenders? Are they HDBaseT? If so, make sure they are running the most recent version of firmware?
  5. stewy604
    stewy604
    Apr 5, 2016
    7
    4
    Vancouver
    They're new to me as of December. I've picked up a replacement set from the installer to do some more testing this weekend. These ones are not HDBaseT.
  6. stewy604
    stewy604
    Apr 5, 2016
    7
    4
    Vancouver
    Just some updates, I was able to solve the problem. Continued troubleshooting, swapped out the Aten baluns to a new set of VE800's, no change...actually worse (couldn't get video signal at all). Swapped to single wire HDMI extenders and voila...works seamlessly!
  7. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Which extender ?
  8. stewy604
    stewy604
    Apr 5, 2016
    7
    4
    Vancouver
    Lenkeng LKV373
  9. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Pity you didnt go for something that met the HDBaset Standard, but if it works thats OK.
    Though it will probably use compression to get down a single Catx cable, no POC or IR either.
    In itself a single catx solution if not HDBaseT can be worse than a dual catx extender
  10. stewy604
    stewy604
    Apr 5, 2016
    7
    4
    Vancouver
    The hardware was free, so I can't really complain. It works...no issues, HD feeds, BD, and 4K.
