Solution For Bathroom Tft Installation
Discussion in 'Home Cinema Building DIY' started by carlosbrunos, Apr 17, 2005.
  1. carlosbrunos
    carlosbrunos
    Hi All,
    I worked in IT for 5 years before going to work for our family bathroom showroom.
    Yes its true that you cannot have mains supply in the bathroom (take underfloor heating for example, the thermostat control has to be situated outside). But you are allowed to do it with 12V IF the unit is SEALED. Take a look at IP65 and IP68 guides for spot lights in a bathroom.
    I am shortly going to try and install a TFT (32in) in my bathroom. I'm going to stick it in a stud wall (inside a perspect housing, with a rubber 'o' seal for the power cord) and then stick a thick peice of glass in front of the TFT, 2-3in's work. This gets around the problem of condensation (also purchase laminate glass).
    Hope this helps people.
    Carl :)
  2. carlosbrunos
    carlosbrunos
    Also forgot put a RCA trip on the plug of the TFT so that if a short does happen (due to water) then the power will cut, and you won't die in your bath!
    Carl
  3. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    probably not worried just wondering illegeily, having an TFT inside an stud wall would be classed as having 240v in an bathroom? as wouldnt that section be part of the bathroom?
  4. gazzerdaman
    gazzerdaman
    Mar 31, 2005
    92
    Chelmsford
    +5
    Think you mean a RCD mate - and I doubt this would confirm to building regs unless you use a LCD model specifically designed for use in a bathroom environment
  5. carlosbrunos
    carlosbrunos
    Building regs are fine as long as the unit is sealed, though this greatly depends on location within a bathroom (as they have different zones, checkout down lighters IP zones). Also my Samsung 172w TFT is 12v and the transformer is 1 and half meters down the cable, with this i'd only be taking 12v to the bathroom.
    Interesting thing though, are there fire regs about putting stuff in stud walls?
  6. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,232
    Middlesbrough
    +140
    It does not matter where you situate the transformer, it is the transformer that is the problem. You must use the correct type.
    See the other thread.
    Johnny.
  7. IronGiant
    IronGiant
    Jun 7, 2003
    54,147
    Oxford UK
    +30,137
    Apart from wondering why you want a TV in the bathroom :rotfl:
    240v Electrically heated towel rails, showers, heaters etc are all allowed in a bathroom, so long as there are no plugs. If all wiring is hidden away it shouldn't be a problem. So long as you did it before the new wiring regs kicked in at the beginning of year :oops:
    Dave
  8. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    have just installed a combi boiler in bathroom and meets all regs - power supply is through wall with no plug in bathroom and boiler is in cupboard with louvre doors :D
  9. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,232
    Middlesbrough
    +140
    All of the above are fine in bathrooms, so long as all supplementary bonding is
    installed correctly, and supplied by RCD.
    The wiring regs. have been around for quite a few years, it is the building regs.
    part P that is new.
  10. rossimmvii
    rossimmvii
    hi,
    im also installing a boiler in the bathroom in the corner with a cupboard to go around it, but does it still comply with regs if, with the cupboard door open, the boiler and sink are both in full arms span reach?
    does the cupboard need a lock on it, (regs access issue).
    where did you install the fused spur if not in the bathroom?
    how did you make the connection between the flex from the spur and the flex of the boiler?
    Any information would be greatly appreciated.
    daniel.streete@carillionplc.com
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    I suggest you contact a Qualified electrician. It is possible bathrooms are zoned so it has to a certain distance from the "wet" areas
  12. Steve1951
    Steve1951
    Jan 27, 2007
    346
    +16
    This is a strange one..........
    If by boiler you mean a central heating gas boiler,you shouldnt be doing it at all you need to be CORGI registered which you obviously arent.
    I n theory you can install yourself if a CORGI engineer does the gas part but thats most of it and they dont like doing that and putting their name to it.
    Thats to say nothing of the Part P bit for the electrics.
    DIY has its limits.
    Regards
    Steve
  13. benwillcox
    benwillcox
    Sep 21, 2004
    294
    Telford
    +22
    Actually that isn't strictly true, contrary to popular belief. Not that I'd advise it though. However you would indeed have to notify under Part P for electrics in a Bathroom, and I think boiler replacement also now has to be notified under Part L, although I'm not certain about that.
    Ben
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    to relocate a boiler you need buiding approval and possibly planning i think defo need a proffesional opinion.
  15. albriscoe
    albriscoe
    May 29, 2007
    5,356
    ideal home cinema dem room
    +522
