Solid timber for DIY rack, what are the costs?
buns
I found that custom prices around here are totally nonsensical so I have ended up making my own..... looks reasonably good considering im a total amateur. I just have the doors to complete then it is totally done :D
I would post pic...... but they are too big to fit :(
ad
buns
Shall do Taz..... might not happen tonight though..... for some reason my connection is like treacle tonight..... :(
ad
buns
it is all running a bit smoother now...... must have been ntl doing something daft :eek:
Sent you a pic Taz....
all the best
ad
T
Taz
:smashin: Very nice indeed, I hope your proud, you should be, its great. If you get stuck with the doors, gie me a shout and I'll see what I can do. ;)
Hope you dont mind, but..........
buns
thanks Taz! I have 2 of the frames for the doors made, it is just a case of getting the fabric attached..... so hopefully the finishing will now be easy!
For anyonw wondering, that is not my permanent display, panny plasma will be ordered some point today!
ad
dgc
Buns, what type of material did you use in the end (wood/mdf/chipboard/other ?)
Looks good
buns
Thanks Eviljohn! :)
Charlie, I ended up using contiboard..... veneered chipboard
ad
eviljohn2
Any plans to add feet at some stage? The bottom components will get very dusty very quickly otherwise.
I'm also using some contiboard in my "rack". It came out really well after a couple of coats of matt black paint and wasn't too expensive.
By "rack" I mean I've got a stack in this order:
Lamp
Coaster
Denon 1802 amp
Shelf
Squash balls
Thin pads to stop rubber damaging veneer of...
BK XLS200 sub
Doorstops
Shelf
Carpeted floor
It's amazing what can be constructed with a bit of thought and some gravity! Unfortunately the amp's a bit lopsided because of the large heatsinks on one side squashing the squash balls :blush:
buns
:D I use squash balls for the speakers...... you cant see them in the bic because they are installed in the wall (pretty good given their size!). The feet I fave considered but the whole thing is very heavy and I dont know I can be bothered lifting it! In any case, their will be doors going on the front (wooden frame with acoutically tansparent cloth inset) which should help the dust issue. Might get it all completed tomoz...... will post when i have :)
ad
T
Taz
Originally posted by eviljohn2
Rather than dedicated feet, maybe some strips along the length and a cross in the middle for strength?
Plinth assembly... lets get the terminology correct please:lesson:
:D
buns
Originally posted by Smurfin
Looks great mate, shame about those dodgy Taiwanese power amps;):D:devil:
Cheeky Git! I'll have you know those are Serbian...... remember what happened last time someone called them dodgy!? :p
ad
T
Taz
I'm a physicist, not a joiner!
Please correct me if I'm wrong, but I'll pick you up on wave and electrical theory in other forums. :laugh:
I got the idea across anyway ;)
And i'm a programmer not a cabinet maker hence the :D
:smashin:
buns
One door completed and a short term 'plinth' solution added :D
how come I can never get pics to fit on here!? What do i need to resize to the right size and where do i download it?!
ad
T
Taz
When you reply, under the smilies look for Attach file.
Maximum size is 102400 bytes (I stick to 500 x 500 pixels)
Valid file extensions: gif jpg png txt zip bmp jpeg mid
Click the Browse.. button and locate the image on your PC.
Then submit reply. :)
HTH
buns
I do all that..... but I almost never manage to have a picture of an appropriate size. If it is too big in memory, then i downsize and it inevitably then tells me it is too big in pixels..... so most often im so peed off by then that I give up!
ad
Podcast: LCD TVs for Movies, Laser Projectors, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
Trending threads
Latest News
QDC Blue Dragon earphones on sale in UK
  • By Andy Bassett
  • Published
TV licence fee now applies to over 75s from 1st Aug
  • By Andy Bassett
  • Published
New H.266 video codec promises 50 percent data saving
  • By Andy Bassett
  • Published
Toshiba launches UL20 4K HDR TVs from £299
  • By Andy Bassett
  • Published
LG GX soundbar launches in UK
  • By Andy Bassett
  • Published
