Solderless modding (X-Box)
Discussion in 'Nintendo Forums' started by thfcwestlower, Oct 17, 2004.
  1. thfcwestlower
    thfcwestlower
    Sep 26, 2004
    184
    +11
    I am looking to mod my X-Box (purchased a couple of weeks ago) so that I can get prog scan output, but would prefer to do it myself and have seen some solderless modding chips here:
    HTML:
    http://www.whitedog.co.uk/catalog/default.php?cPath=9_91&osC
    Would you recommend that I go through this route to get the X-Box chipped?
  2. dUnKle
    dUnKle
    Jan 1, 2001
    13,484
    +1,410
    I got a non solder chip and new hard drive
    chip is not difficult to fit but it can be "fiddly" and a bit scary - but follow the instructions and you should be fine
  3. daz500
    daz500
    Oct 10, 2004
    46
    Belfast
    I wouldn't bother fitting a chip as a software modification is very easy to do.
    I've just done a friends xbox and it took no more than 5 minutes without even opening the box.
    larger hard drives are also compatable :smashin:
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,340
    Windsor
    +1,026
    daz, how easy is the software mod? I'd be tempted, as then I can just get a box off the high street and I'm away.
    I only want it for Xbox media center over network.
    Once softmodded, does it stay like that? I don't mind never using that one for live (got one in the lounge for that)
    pm if its sensitive :)
  5. daz500
    daz500
    Oct 10, 2004
    46
    Belfast
    A soft mod is very easy and can be easily reversed for when you do want to go on XBOX live.
    I've done this using a hack for James Bond 007: Agent Under Fire but there is also one for Splinter Cell.
    Basically, get yourself 007 from the local 2nd hand shop (or ebay) and a memory card. If you know someone with a chipped box then an original memory card is OK otherwise get yourself an action replay one. In fact, buy my AR as I don't need it anymore ;)
    If you want to install a larger hard drive then its a wee bit trickier but not impossible.
  6. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    daz - I know you joked but do you want to sell your action replay? If so how much (inc. p+p)?
  7. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Also should add a warning to original poster - if you're xbox is a v1.6 then there is no solderless chip option available yet anyway.
    Can't believe I'm helping a spurs fan....
