Sold a pronto - buyer says not working - any ideas whats wrong
Discussion in 'Home Cinema Control & Remote Controls' started by dUnKle, Oct 11, 2004.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,479
    +2,382
    Sold my pronto last week on ebay but buyer says its not working - says he can get no display on the device
    it was working fine prior to me sending it - in fact was being used almost up til it being posted
    any ideas what could be at fault
  2. Supra
    Supra
    Dec 12, 2002
    433
    Kent
    +14
    Has he tried setting the contrast, he may have accidently moved the setting. Also worth checking the batterys are inserted correctly.
    I bet it is the contrast setting.
  3. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    Over the Hill & Far Away
    +139
    yeah mine caught me out a few times where the contrast was knocked etc and the screen stayed blank.. utter panic attack until I turned it back down !
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,479
    +2,382
    Its looking like there could be a problem
    States that tried contrast and nothing
    sold it with the charger - states light on charger is on but does not go off when remote is sat on it
    if remote was in front of me I may be able to sort it - was there not a reset switch on the back ?
  5. Supra
    Supra
    Dec 12, 2002
    433
    Kent
    +14
    Yes there is a reset feature, more like a reset hole than a switch. It is located at the back, I have used it before, you have to prod a paperclip or similar in there and wait.
    The buyer could have tried to re-programme it and done something stupid, he may be making an excuse.
    Good luck sorting it out
  6. stevej
    stevej
    May 21, 2003
    197
    2
    +3
    My Pronto is suffering exactly the same problem. The screen remains blank, but when it’s on the charger the green light is on. I’ve tried everything but it’s dead! :confused:
    If you’re able to sort this out I’d be very interested to know how you did it.
  7. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    883
    Lancing, West Sussex
    +73
    On occasions I've dropped mine and the battery pack has become dislodged. There was a procedure for locating the battery properly - I remember there being a special note about it in the box when new. Try removing and re-installing battery - make sure lugs are located and push down until it clicks into place - need to be quite forceful to get it in properly. Worth a try.
  8. mjn
    mjn
    May 24, 2001
    22,723
    Herts, England
    +10,867
    Re-sit the battery pack, as if the battery stays on, its charging.
  9. Loada
    Loada
    Mar 4, 2003
    592
    Guisborough, North Yorkshire
    +51
    Echo the others with it pointing to the battery pack. If necessary, take the battery out and leave it overnight. Then place it back in and make sure it goes in properly - you might want to consider cleaning the battery contacts in the Pronto itself. Another tip is to be fairly aggressive when putting the battery back in to make sure its seated firmly. You should then see it charging correctly (and subsequently, the Pronto working).
    Worst case scenario is that the battery may be dead - can he attempt to use some normal AA batteries just to confirm that the Pronto is working?
