Solarisation problems...
Discussion in 'Plasma TVs Forum' started by Meggeh, Apr 14, 2005.
  1. Meggeh
    Meggeh
    First post! But have been lurking for a while.
    Ok, I know that you'll probably tell me "Fancy buying one of those!", but it was a very good offer that I couldn't refuse. I bought a Philips 37PF9946 plasma, and give it a decent signal (good NTL channel or dvd) its fine, pretty impressive even. However, if the signal isnt that good, and under certain viewing conditions (especially faces/flesh tones), solaristaion problems can be quite off-putting.
    I would like to know if there are any external decives that could be used to improve this. For example, would a unit to go into the PC type 15 pin input help? Ive seen this at Maplins -
    http://www.maplin.co.uk/Module.aspx?ModuleNo=37141&TabID=1&WorldID=&doy=14m4
    Would this help out?
    Any other suggestions would be appreciated.
    Thanks.
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I dont think that would improve the quality of the signal if your using scart anyway. Are u using a high quality full RGB scart?
  3. Meggeh
    Meggeh
    I have a scart connection from the NTL box to the plasma, not sure if its full RGB tho. Its a cambidge audio - but not an expensive one (richer sounds at about £10). Would a better quality scart connector help much?
  4. pwood
    pwood
    Dec 6, 2003
    2,569
    Central Scotland
    +163
    Lead should be fine. Check NTL box is set to output RGB and not composite.
  5. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    the js converter will do a much better job than the sync blaster ( i have used both).....but don't know if it's philips compatible....the js web site will tell you. www.js-technology.com
