Solar Wind Terminations
Discussion in 'Cables & Switches' started by patmyhead, Dec 31, 2003.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    I have a 8m & 7 m lenth of solarwind speaker cable
    anyone do or know where i can get the ends reterminated for biwireing or is there a easy way to get good results doing it myself :rolleyes:
    P@T
  2. clouseau
    clouseau
    Hi, this as I guess you realise is tricky, my advice is do not do it yourself. The difficulty is in removing the outer sheath from the wire and can get very messy...
    I have similar lengths of SW and got my local hifi shop to do it . Leicester Hifi though I think they would be happy to admit its not really their thing.
    There is a dealer, I think in or near Chester, that advertises a retermination service - probably charge £50ish and you will need to send it to them etc..
    I suggest you telephone Nordost and ask them who they recommend...
    Good luck
