Software version for AV32R?
Discussion in 'TAG McLaren Audio Owners' Forum' started by Smurfin, Aug 22, 2004.
  1. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,349
    I've just bought a cheap Tag AV32R (base spec except with PLII enabled), and the current software version is something like 3.45. I'm sure there have been many updates since this one...is it worth the hassle of getting a Tagtronic cable to load up the latest software?
    If so, how would it change the performance of my Tag? (which is excellent btw:))
  2. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    Livingston, Scotland
    +227
    Smurfin the latest for AV32SP is 3.8 but as you say you need the cable. There were a lot of fixes over the various software releases but I can't remember what they all were.
    The "old" forum had a list of them so check to see if they are still listed in the IAG site
  3. Dr Udo Zucker
    Dr Udo Zucker
    May 14, 2004
    358
    Portugal
    +35
    Hi, I cannot remember v3.45 for the AV32R SP. The list of software was, as far as I recollect: 3.4, 3.40.1, 3.5, 3.50.1, 3.6, 3.7, v3.75 and finally v3.8. So a very long list of upgraded and associated changes. Definitely worth upgrading to v3.8 in my opinion :thumbsup: .
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +135
    Sure theres a thread here that mentions the versions and what changed.. I have 3.75 so I don't think its worth getting the cable to upgrade.. I'll wait till I upgrade the machines DAC's etc and get the heldpdesk to upgrade it at the same time!
    Matt
  5. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    There was V2.02-V2.03-V2.04-V3.01-V3.11.211-V3.20.1-V3.3-V3.40-V3.40.1
    V3.50-V3.50.1-V3.60-V3.70-V3.75-V3.80
    i'M SAD I KNOW :suicide:
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    There was even a V2.01 on our original unit........(I'm surprised I remembered it......). I'd always use the latest version compatible with your device/options.
  7. AMCross
    AMCross
    Dec 3, 2003
    6,006
    Livingston,Scotland
    +205
    Now GrahamMG that must have been a prototype
  8. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    well it didn't work well as I seem to remember due to a duff batch of some component and was fixed almost overnight and came back with v2.04 so......Nice lunch with Jo Graham when I picked it up as I also seem to remember!
