Software upgrades for AV32R single processor
Discussion in 'TAG McLaren Audio Owners' Forum' started by P Adams, Nov 4, 2003.
  1. P Adams
    P Adams
    Nov 1, 2001
    224
    Hampshire
    +20
    Thanks for the suggestions on upgrading my AV32R and Rotel system
    I was wondering whether there are any worthwhile upgrades for the system software on my AV32R 7.1EX single processor, non-bypass version?
    The system software at the moment is V3.70 or V3.75 I'm at work at the moment and I can't quite remember!
    PA
  2. mark67
    mark67
    As far as I know V3.70 is the latest Software for the AV32 SP.
    Do you have the 192/24 DAC in your AV32 SP? Did you notice any difference between the 94/24 DAC's and the 192/24 DAC's.
    Cheers.
  3. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    The last version was 3.80.
  4. mark67
    mark67
    My mistake, V3.80 is the newest software :lesson: .
  5. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Hi mark....slightly off topic I know,but I haven't got the 192 Dacs in mine,but do use an upsampler to run the DAC's at 24/96 resolution,and whilst not as good as the Perpetual Technologies P1A/P3A together,it's close enough to make it convenient and easy to use things this way.
    I know it's not a cheap solution,but I did have the DAC and upsampler lying around idle after adding the AV32R to my system.
  6. OnTheFly
    OnTheFly
    Jul 2, 2002
    2,871
    83
    Everywhere
    +105
    As far as 3.80 goes, it is only generally for those running one of the matching DVD players. One can load it without problems (I have) but 3.75 is sufficient for 'us' peasants!:suicide:
