Software Upgrade For Panasonic TX32LXD52
Discussion in 'Panasonic TVs Forum' started by RyanK, Oct 25, 2005.
  1. RyanK
    RyanK
    Sep 20, 2005
    1,104
    London
    +38
    Does anyone know how to find out when their are updates for the Panasonic TX32LXD52?
    I refuse to leave my TV in standby mode over night
  2. Del45
    Del45
    Feb 24, 2005
    893
    28
    +39
    The updates are only for the freeview part of your TV afaik.
  3. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    Hi RyanK
    You can also do a manual search for updated software from the Freeview menu, the version currently is 1.65.
    Regards
    Phil
  4. mr-monday
    mr-monday
    Jul 19, 2004
    428
    28
    +31
    Isn't there a main power switch on this set?
  5. drbober
    drbober
    Jul 28, 2005
    46
    What's wong with the switch on the front?
    Does this only put the tv on standby?
    I don't think it does cause you can't switch it back on with the remote when you turn it off in this way.
  6. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    I think the switch on the front is indeed a mains switch, it feels like it. The manual does say something about leaving the set in "Standby" to get the updates, if switched off at the front it will never get them.
    Regards
    Phil
