Software to read *.VRO files ?
RecordablDVDfan
TMPGEnc DVD author reads the VRO as separate files but I get 'this program is a mix of different formats' on older DVD RAM recs. I know why and have changed settings on the E50 to sort this
Is there any other s/w which behaves like TMPGEnc DVD author as all s/w I've tried just reads the VRO file as one file which is not what I want...
Party Animal
I think you are trying to make a DVD using different clips with different bitrates. ...
authoring programs usually spit them out
dvd recorders will let you.. but PC authoring programs usually dont
:hiya:
RecordablDVDfan
I've got a copy of Ulead DVD Movie Creator 3 which reads VRO files and it does see the file as seperate files. Problem is it's so slow at encoding all the files prior to burning on DVD...
I wish there were more authoring progs which would accept VRO / DVD RAM files...
