Software to easily select media?
Discussion in 'Desktop & Laptop Computers Forum' started by janmars, May 23, 2003.
  1. janmars
    janmars
    May 4, 2003
    162
    The the process of setting up a HCPC. Have it all hooked up to my TV now (as per my other posts. And haven't quite decided to get a projector yet).
    Anyway...gonna be using IRMan to control the PC...and most of the files will currently be playing through Windows Media Player.
    Currently, when I select different files, I have to use the "file open" option, and then locate the file. What I would like, is a piece of software that displays "My Videos" folder...or all my movie files, in a manner that is somewhat like a "Chapter selection" on a DVD. This would make it much easier to locate my videos, rather than having to navigate through various directories.
    Is there anything out there that I can use to do this?
    Thanks...
  2. Blight
    Blight
    Zoom Player has a media library navigator which allows you to browse specified directories. Or a File Navigator which allows you to browse through the entire system. All in a remote-control friendly interface (based on Girder).
    Frankly, using WMP on an HTPC system is next to lunacy.
  3. janmars
    janmars
    May 4, 2003
    162
    Thanks.
    Only set this up yesterday so only a little looney... ;)
    I will have a check of that software.
  4. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    also try this software:
    http://www.myhtpc.net/
    it's quite easy to set up after a short learning curve (especially if I can do it!)
