Bargain Expired Software giveaways
Shining MP4 Converter v6.6.6 (lifetime license)
by ShiningSoft
Convert Any Video to MP4 without quality loss!
MP4 Converter helps you convert unplayable video formats to popular MP4 videos for watching on computer, portable devices, including iPhone, iPad, iPod Touch, Android Phones and Tablets like Samsung Galaxy series.
What's more, you can import incompatible video formats to video editing software including Sony Vegas, Adobe Premiere, Avid Media Composer, Windows Movie Maker, Sony Vegas Movie Studio/Pro, Adobe Premiere Express/Elements/Pro, After Effects, Encore, Pinnacle Studio, Nero Vision, Roxio Creator, Magix Movie Edit Pro and Ulead DVD MovieFactory with the help of Shining MP4 Converter.
System requirements: Windows 10/8.1/8/7/Vista/2000/XP
Get the best software for Windows with the Giveaway Club for free!
FREE 5-6 May
Shining MP4 Converter v6.6.6 (lifetime license) for FREE from Giveaway Club on May 5 - 6 only. Hurry and grab your license now!
Dimo HD Video Converter giveaway
World's NO.1 Fast HD Video Converter to download, convert, compress, edit and wirelessly share HD MKV MP4 AVI H.264 H.265 video files in a flash with zero quality loss.
Giveaway limitations:
* Strickly no commercial use
* Remember to activate the program before May 31th, 2018
* Giveaway users will not be eligible for free upgrade services
* This giveaway product has no functional limitation
Requirements:
Supported OS: Windows 10/8.1/8/7/Vista
Dimo HD Video Converter free software giveaway
Top Rated HD Conversion Solution: WonderFox HD Video Converter Factory Pro Giveaway [Official]
Every user can free download giveaway version till Jul 1st, 2018. Faster speed and lossless HD conversion experience will dramatically enrich your life.
WonderFox Soft Giveaway and Discount: A special gift to all readers
Top Rated DVD Ripping Solution: WonderFox DVD Ripper Pro Giveaway [Official]
Every user can free download giveaway version till Jul 1st, 2018. The number 1 DVD ripper software, Rip a DVD to digital copy in 5 minutes with flawless 1:1 quality.
[Official] WonderFox DVD Ripper Pro Giveaway and Discount: A special gift to readers
CyberLink Power2Go 11 Deluxe Free License
published on June 18, 2018byAuthor Ramakanth 1 Comment
CyberLink Power2Go is the all-media burning software for Windows Systems, this software supports all drives and discs, including CD, DVD, and Blu-ray Disc.
With CyberLink Power2Go you can create and burn data discs, music discs, photo gallery discs, and video discs.
You can also back up your computer to a disc or removable USB storage drive, convert media files for use on mobile devices, view a library of your burned discs in the Disc Manager, or use the handy disc utilities to erase and copy discs, mount disc images as a virtual drive, and much more.
CyberLink Power2Go is the all-in-one burning software for the PC.
CyberLink Power2Go Deluxe Full Version Free License
Acoustica Standard Edition 6 Free Download
Posted on August 14, 2018 in Audio / Video Editors 6
Are you into music production? Do you need an audio editor that supports multi layers and allows you to easily edit and mix audio tracks? Then look no further as Acoustica will handle all your audio editing needs without needing you to reach out for help from a professional.
Acoustica Standard Edition 6 Free Download with License Key
Videomizer 2 Free Download
Posted on July 15, 2018 in Audio / Video Editors 0
Videos recorded from smartphones and other handheld cameras often add shakes and vibrations to your videos. Most of these handheld devices lack optical image stabilization technology, which is why you may end up with shaky footage even when trying to record with a very steady hand. Shaky footage can be corrected with video optimization programs, one of which is Videomizer.
Videomizer 2 Free Download with License Key
Giveaway of the day — WonderFox HD Video Converter Factory Pro 16.2
Power up your videos and save space on your devices!
WonderFox HD Video Converter Factory Pro is designed to convert normal and HD videos, download 8K, 4K, 1080P, 720P, etc. videos from 300+ sites for offline playback, and edit video in virtually any format.
Main Features:
Supports hardware encoding (Inter QSV, Nvidia NVENC).
Converts HD video to general video and reduces video size without quality loss.
Converts SD video to HD video (improves video quality with advanced high-definition video encoding core).
Downloads video in 8K, 4K, 1080P, 720P, 480P from 300+ sites.
Converts audio files and has a built-in ringtone maker.
Has A Built-in editor (Merge, Subtitle, Crop, Clip, Rotate, Volume, etc.)
Power up your videos and save space on your devices! FREE with GOTD!
HD Video Converter Factory Pro v.16.2 (lifetime license)
by WonderFox
  • It's designed for HD video conversion. It can power up your videos and save space on your devices. Meanwhile, it can convert videos to 300+ formats and devices.
  • 4K (UHD), 1080P (FHD), 720P (HD), 480P(SD) Conversion Full Control;
  • Outstanding 5X Compression Rate. Watch Video on Hand-Held Devices Anytime, Anywhere;
  • Built-in audio converter for professional-quality sound. Keep music right between your ears after conversion;
  • YouTube to MP3, MP4, AVI downloader;
  • Make your videos pop: Remove unwanted parts; Create video clips; Merge files; Have fun with effects;
  • A real time Saver- 50X Faster Video Conversion Speed;
  • Besides, you get more apps in one: ringtone maker; volume booster; auto upload converted files (FTP) and shut down after done; ViSubtitler;
  • Solve format compatibility problems for up to 300 gadgets;
  • Compatible with Windows 10/8.1/8/7/Vista/XP;
  • Special offer for Giveaway Club users
HD Video Converter Factory Pro v.16.2 (lifetime license) for FREE from Giveaway Club on Aug 26 - 27 only. Hurry and grab your license now!
Leawo DVD Creator makes the best DVD from all video sources including homemade clips and downloaded movies in video formats like AVI, MKV, MP4, WMV, Xvid, MOV, FLV, and more. With this DVD Creator, you can burn video to DVD (DVD-5, DVD-9) disc, folder and/or ISO image, and directly burn ISO file to DVD disc.
Convert all video files like MP4, AVI, MKV to DVD disc fast;
Create DVD-5, DVD-9 disc, folder and/or ISO image without quality loss;
1-click operation to create photo slideshows and burn to DVD easily;
Present multiple menu templates and custom design;
Easy edit video effects, support 2D to 3D conversion.
Please note: The software includes a 1-Year license. Leawo DVD Creator works as a module of Leawo Prof. Media suite.
Leawo DVD Creator is a professional home DVD creating program. FREE offer on GOTD!
HD Video Converter Factory Pro + Back to School Campaign ( 8+ giveaway software & 350$+ Total Value)
by WonderFox
Enjoy Substantial Gifts and Huge Discounts in WonderFox 2018 Back to School Giveaway Feast!
HD Video Converter Factory Pro is designed for HD video conversion. It can power up your videos and save space on your devices. Meanwhile, it can convert videos to 300+ formats and devices.
FREE TODAY!
Regular price $34.95
HD Video Converter Factory Pro + Back to School Campaign ( 8+ giveaway software & 350$+ Total Value) for FREE from Giveaway Club on Sep 3 - 4 only. Hurry and grab your license now!
Handy tool to record the computer screen.
Vov Screen Recorder is handy tool to record the computer screen, i.e., record the ongoing activities on the screen. Using Vov Screen Recorder, you can record your screen to create a how-to video to demonstrate working of a program, compile a products demo video for some client, record gameplay to post on social networks or record any other activity on the screen to share with friends or stakeholders, or to upload on video streaming services like YouTube.
Free Vov Screen Recorder (100% discount) | SharewareOnSale
AnyUTube is the best YouTube assistant to download & convert YouTube video and music. It also allows you to download any playlist from YouTube, as well as any video from Channel. The latest version also supports for downloading subtitle.
Search Any YouTube Video Fast
You can get the desired video by searching for anything about the video or simply paste the video URL (YouTube playlist & channel supported).
Download YouTube to MP3, MP4, M4A etc.
There are multiple format options at AnyUTube, and you can easily download any YouTube video to any latest format as needed.
Free AnyUTube (100% discount) | SharewareOnSale
Aiseesoft Slideshow Creator is the easy-to-use video weaver with photos, videos and music files in high resolution (4K supported). It makes slideshow movie with BMP, JPG, JPEG, PNG, TIF, TIFF, ICO, DIB, JFIF, EMF, GIF, MP4, FLV, WMV, MTS, AVI, MOV, MP3, AIFF, FLAC, AAC, AC3, WAV and more. You can create a quick movie with the ready-made themes, and customize slides by combination of text, filters, transitions and elements freely. Adding background music/subtitle and editing video (crop, clip, rotate, mirror, fast/slow motion, crop, etc.) can be supported fully.
Note: This software is compatible with Windows computer on 64 bits.
Create slideshow videos with photos, videos and music. Free on GOTD!
The perfect 4K video converter which allows you to convert 4K video to other 4K video format, and converts 4096 x 2160 resolution to 1920 x 1080 and 1080 x 720 video for using.
Supporting the latest 4K encoding/decoding technology, this super 4K UHD converter lets you convert 4K video to 1080p, 720p HD and SD videos or convert 4K videos from one format to another popular 4K video format.
Free 4K Video Converter (100% discount) | SharewareOnSale
Enhance video quality, rotate or flip video, adjust video effect, make video clips, crop video area and add watermark with ease. Get Aiseesoft Video Enhancer Registration Code includes free lifetime upgrades & support with 70% discount coupon (For Windows or Mac OS X) in our software promotion of the day. You can also get Aiseesoft Video Enhancer full version key for free in the software shop giveaway of the day! Enjoy it!
Aiseesoft Video Enhancer - Review & Free Registration Code Giveaway
4K Video Converter is designed as a professional 4K Converter that downscales 4K videos to 1080p, 720p with different formats and encodes 4K video to other 4K formats, such as 4K MP4, 4K MOV, 4K MKV, etc..
Download your favorite 4K/HD/SD videos from video sharing sites like YouTube, Vimeo, Dailymotion, and more with one simple click for enjoyment without Internet connection; If you download some videos in 4K resolution on your computer, Dimo 4K Video Converter also helps you to convert them to compatible formats for playback on TV, smartphone, tablet or other devices. Note: You're only entilted to download the videos with authorized copyrights.
Giveaway: Mediadimo 4K Video Converter for FREE
Movie Maker & Video Editor: Slideshow Maker Giveaway is available now for a limited time!
Movie Maker & Video Editor: Slideshow Maker Review at a Glance
Movie Maker & Video Editor : Slideshow Maker is the only full-featured professional video editor for Windows, supporting multiple layers of video*, images, and text, as well as precise cutting and trimming, multi-track audio, precise volume envelope control, color LUT filters, 3D transitions, Slow Motion effect, different videos format and much more.
For professionals and amateurs alike, Movie Maker & Video Editor: Slideshow Maker offers an unprecedented level of control over the mobile/PC editing process, and for artists and educators, . Our users include mobile/pc journalists, YouTube creators, short film producers, educators and other professionals from various industries around the world.
Movie Maker & Video Editor: Slideshow Maker - Review & Free License Giveaway
Is Home Theater DEAD in 2024?
Back
