Software for Photo Slideshow on DVD?
Discussion in 'Photography Forums' started by handles9, Jul 15, 2005.
  1. handles9
    handles9
    May 4, 2004
    27
    Guys, hoping you can help me - I'm looking for recommendations around software I can use to make a slideshow of photos to music that can then be burnt to DVD for playback from a DVD player, not PC. Ideally the software would be cheap as I'm only going to do this once....
    :D
    Any suggestions gratefully recieved...
    Oh yeah, it would be cool if the pictures were moving around as part of the slideshow...
  2. Johndm
    Johndm
    Jan 25, 2003
    1,804
    Bedford UK
    +56
    Cyberlink Powerproducer worked fine for me. Used mp3's for the music.
    It came bundled on my PC, so don't know how much it is to buy
  3. Pinoy
    Pinoy
  4. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
  5. paulnewsom
    paulnewsom
    Apr 18, 2005
    York
    I use "Pictures to Exe". A superb pice of software only available on download from www.wnsoft.com. You can download a trial version. Cost of full version is around $24 and can be available immediately.
    It will prepare a self executing file to play your slideshow from PC but can be burnt onto CD or DVD using most DVD burning software. I use Ulead Movie Factory for this part. The programme is easy to use and the help files are good. There is also a good forum for the software with a section on creating DVD's at www.picturestoexe.com/forums/
  6. handles9
    handles9
    May 4, 2004
    27
    Thanks for the advice so far guys - I'll try them all... PauNewsom, I'm confused - it seems Movie Factory should do it all - what does PicturesToExe do that Movie Factory wont?
  7. HMHB
    HMHB
    Nov 11, 2001
    25,516
    Nottinghamshire
    +3,852
    I use Proshow Gold as well :thumbsup:
  8. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Have a look at Magix photo and CD Deluxe 4 at PC world only £15 does the lot loads of effects sound and vision Better still have a look at their website www.magix.net plenty of info on there
  9. paulnewsom
    paulnewsom
    Apr 18, 2005
    York
    I have tried other software that does slideshows and a host of other things. Pictures to exe simply creates a slideshow form which you can make an executable file which you can use on a PC, but you can also create an AVI file to save to DVD or CD and play on a DVD player. What it does, it does superbly and the timeline and waveform is a dream to use. I have tried Roxio, Microsoft and others. This stands ahead of them so I stuck with it see some shows here http://homepage.ntlworld.com/paul.newsom/html/slideshows.html
    I can send a tutorial if you are interested.
    Paul
  10. bodmin636
    bodmin636
    Jun 20, 2005
    19
    If you have win xp the built in movie maker can do that at no extra cost, quick and simple especially if its only a 1 off.
  11. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    The program you have used may make an excellent job of presenting pictures but no one will ever see them if they are offered as an executable file. Even if I knew you personally I would never download a .exe file from a private website (apart from known software sites).
  12. paulnewsom
    paulnewsom
    Apr 18, 2005
    York
    Thank you for your judgement.
    And I suppose that "endeth the first lesson" if you don't have the right protection.
    However, that was not the point of the question.
  13. Tommy139
    Tommy139
    Jan 27, 2003
    229
    Manchester
    +13
    There is one piece of software that i would strongly reccomend that you avoid, that being Uleads DVD Pictureshow.
    Check out their support forums and you will see that there is no end of problems with this one.
    I can though vouch for ProShow Gold.
