Software - choose specific channel from 7.1
stevos
Not sure which sub-forum to put this, for max the chance of a reply but here goes nothing.
I am wondering if there is any pc software that allows you to play, ideally music or audio of your choice (what i want is real audio and not a test tone), through specific channels of a 7.1 setup.
What i want to be able to do is play the same music and move it through each channel and see how the sound compares and get a real idea of what accustical problems there might be in the room. I know i can use roomeq to measure it, but that is just a graph and i don't know how to convert that in my mind to real sound.
next010
The only thing I've seen close to that is in MPC-HC under options->Internal Filters->Audio Switch you will find custom channel mapping but I've no clue if it does exactly what you want.
If not maybe dedicated music players might have the feature have a look around the audio player section of videohelp.
stevos
thanks will check out mpc-hc. my guess is all I need is a way to turn down the volume on individual speakers
stevos
Almost works using mpc-hc.
I can't seem to reassign a input to another channel, but can mute individual channels.
I guess i need to find an audio file that is playing the same sound out of all 7 channels
paulst10
Can you set your Marantz to all channel stereo then unplug the individual speakers from your power amp?
stevos
i could but it's a pain reaching behind as rack doesn't have wheels and now weighs a ton with all the gear
paulst10
You could try disconnecting the speaker wire from the back of the individual speakers
stevos
kinda same problem. my surround 4 and heights are all wall mounted and so would require taking them down to unplug. doable but a pain if testing each channel or trying to AB between options.
