S
Sweden
Is there a newer upgrade to dv88 plus ?
Yes, to 5.8. For US customers it's posted here.Sweden said:Is there a newer upgrade to dv88 plus ?
dwette said:Yes, to 5.8. For US customers it's posted here.
nikbedwell said:Does anyone know whether it is safe to install this update on a UK DV88Plus ?
Yes i've rung my Arcam dealer and all they can do for me is ring Arcam to get the latest CD, then have me bring in my DVD and wait a few days while they perform the update.
I'm a computer engineer and have already loaded several s/w and drive updates on my DV88Plus so am happy with the procedure. Just want to clarify if US s/w updates are ok for UK players.
Thanks in advance for everyones help.
Nik
That is fixed with v5.13.stevebez said:Does your remote control behave as you expect ...??
I keep finding that every command seems to be duplicated ??
Most frustrating !!!
Rgds Steve.
dwette said:That is fixed with v5.13.
