softmod is actually great?
Discussion in 'Xbox Forums' started by malloy, Jul 22, 2005.
  1. malloy
    malloy
    i jus got my xbox soft modded and it is acutally great.
    i can play ntsc on my pal and i can download games to the hdd.
    its almost to good to be true
    whats the catch????
    help me out here peps
  2. Pooon
    Pooon
    Dec 26, 2002
    7,128
    Canterbury, Kent
    +731
    That doesn't sound like a softmod to me, more like a mod-chip has been fitted
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,269
    103
    +490
    Softmods are functionally equivalent to modding with a chip. There is nothing that a mod-chip enables that a softmod cannot do although some things like adding a larger hard disk can be more fiddly to set up.
    Nigel
  4. Pooon
    Pooon
    Dec 26, 2002
    7,128
    Canterbury, Kent
    +731
    Hmm, so why pay £45 for a chip when you say a soft mod will do the same thing. I have mine soft modded using the splinter cell game save which gave me access to the NTSC video output but i definately can't stream media from my pc through my xbox, i cant save games to the HD, i can't play cd/dvd-r's, i can't us XBMC. so it looks to me like there are a lot of things a modchip can do that softmodding can't
  5. John DB
    John DB
    Jul 29, 2002
    334
    +7
    I recently set up a mates xbox with XBMC as the dashboard using splinter cell exploit (SID 3) and AID 2.02 software. Its exactly the same as a chipped box and can do all the above.
    Catch? Well you can't play on Live! with this set up so that rules it out for me.
  6. malloy
    malloy
    yeh i have the same as above. sept i dont play on xbox live anyway.
    i can play ntsc games and copy games to the hdd. I just need to get a new hdd to put more games on sept you say it could be fiddly.
  7. dataloss
    dataloss
    Apr 18, 2003
    89
    11
    London UK
    +14
    From what I understand the modchip has the fuction of BIOS backup and update, without touching the original MS BIOS. If your softmodded box BIOS gets fragged.:suicide:
  8. mcgetta
    mcgetta
    Apr 12, 2005
    30
    Which dashboards have you guys got loaded?
  9. nigelbb
    nigelbb
    Apr 4, 2005
    5,269
    103
    +490
    XBMC
  10. mcgetta
    mcgetta
    Apr 12, 2005
    30
    I soft modded and have EVo-X loaded, however, I only have the vodswitcher program, anyone know what I need to load onto the C: partition to enable the xbox to play my backup games and region 1 discs?
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    If i modded my box using SC save would that kick me off live?
  12. iainl2005
    iainl2005
    Apr 15, 2005
    342
    Glasgow
    +10
    horny, have you found out if softmodding will get you kicked off live. I have softmodded my xbox using the SC save so I could get the high def options for my plasma. I was going to buy Black Hawk Down NTSC as it isnt out for another 2 months in Britain to play the multiplayer.
  13. iainl2005
    iainl2005
    Apr 15, 2005
    342
    Glasgow
    +10
  14. Trousers
    Trousers
    Jun 16, 2005
    93
    Softmodding for High Def Output won't get you kicked off Live but it won't let you play NTSC games either.
  15. cra41g
    cra41g
    Personally, I don't like the idea of softmodding an Xbox - it should still be able to be run from it's original BIOS. A lot of people, going by what's been written, have problems with softmodded Xbox's.
    Xlink Kai is a superb remedy for Xbox Live, which has a good built-in UI within XBMC.
    PS. Buy an Xecuter 2.6!
