Softmod file for Splinter Cell - can anyone mail it?
Discussion in 'Xbox Forums' started by gavan, Sep 5, 2007.
  1. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +287
    I'm looking to softmod a couple of XBoxes. I already have one chipped box with a memory card and the original Splinter Cell so if anyone could send me, or point me in the direction of, the save file for softmodding I'd be much obliged.
    Cheers,
    Gav
  2. scumball
    scumball
    Jan 12, 2004
    6,526
    Harrow - London
    +451
  3. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +287
  4. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +287
    Update;
    Mate's old Xbox now softmodded - no problems at all, surprised at how easy it was. Anyone with an Xbox knocking around should at least try a softmod.
    Now - to tackle my spare Crystal Xbox. Got a feeling that it might not be so easy. I think it's a 1.6 model.
  5. doomlord
    doomlord
    Oct 22, 2006
    117
    +6
    I agree. It's a lot easier than expected.
  6. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    Version 1.6 XBoxes are easy to softmod too. If I'm going to do one, I just use the Splinter Cell exploit to gain FTP access to the XBox HDD, then I copy a working backup over to the HDD... Really easy to do!
  7. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +287
    Yep - did my 1.6 Crystal Xbox the other night using the same splinter call/SID save and it worked a treat, no problems at all. I know that motherboard revisions caused issues with modchips but no problem for the softmod at all.
    I'm very impressed with whoever put the work into the SID v5 installer - it makes everything pretty foolproof. No need to bother FTPing a dash across as it will install either UnleashX or EvoX for you. Will do a dual boot if you want to use Live and even optimise for HD resolutions.
    Given that a lot of Xboxers moved to the 360 there must be many people out there with old Xboxes knocking around. It's so easy to convert them to a fantastic media centre and emulator box that everyone should do it.....
