Softmod an Xbox via a Modded Xbox..Help.
Discussion in 'Xbox Forums' started by y220186, Mar 17, 2005.
  1. y220186
    y220186
    Dec 24, 2004
    38
    OK, I have been trawling for two days through the xbox-scene tutorials, and have found myself getting more and more confused, so I thought I would ask here, to see if anyone can help.
    Im currently using my xbox on Live, and have a Toshiba 36ZP46 Widescreen TV. :-
    A) If I softmod my xbox and use it with a Hi Def kit , Will be able to get some sort of Progressive image via component, even if my TV doesnt support Hi Def.
    B) Also, is it possible to take my hard drive out of my xbox, put it into a modded xbox, FTP the modified files using an Evox boot disc and then place my drive back into my machine, would this work ?
    C) If this would work, will this still allow me back onto xbox live with the modified files. Bearing in mind it has had an Halo2 update recently, if that makes any difference at all.
    Thanks in advance for your help.
