soft cloth cases
Discussion in 'Photography Forums' started by shahedz, Sep 11, 2005.
  1. shahedz
    shahedz
    Apr 26, 2005
    10,673
    +1,640
    i have just bought a new casion exs lim camera. i replaced my sony with thecasio and am really pleased with it, size to me is a huge factor and i found i didnt use the sony much because i didnt like lugging it about. so the exlim is perfect the only thing is i need a case, i dont see the point choosing a camera for its small size only to have a massive case that doesnt fit in my pocket, i have cehcked out the leather cases but find them too big dont really want to hang it on my belt. ideally i only want it to prevent it getting scratched in my pocket etc , so literally need a soft cloth case, anyone know where i can get one from?
  2. Crocodile
    Crocodile
    Nov 4, 2002
    17,538
    +6,480
    What are the dimensions of the camera?
  3. shahedz
    shahedz
    Apr 26, 2005
    10,673
    +1,640
    the dimensions are 88 X 57 X 17 millimeters w,h,d
  4. Crocodile
    Crocodile
    Nov 4, 2002
    17,538
    +6,480
    Something like this?
    Also try your local Asda/Tesco as they both have some very cheap cases but may not have anything that small.
  5. shahedz
    shahedz
    Apr 26, 2005
    10,673
    +1,640
    something like that is too big,i literally want to be able to put the camera in my trouser pocket and be able to take it out, does anyone remember the soft draw string cases you used to get with Sony Minidisc players? something like that would be ideal. just to prevent it from scratching,cheers for the link anyhow! :thumbsup:
