Socket 939 NF4 Motherboard - passive cooled. Which one?
Discussion in 'Computer Components' started by OneEleven, Sep 8, 2005.
  1. OneEleven
    OneEleven
    I'm looking to build a games machine around a Dual core AMD64.
    I was looking at the Abit AN8 Ultra, and the Gigabyte GA K8N Ultra 9.
    What drew me to these boards is the fact they have passive chipset cooling. I want this machine to be quiet and will be investing a lot in quiet cooling (Thermalright XP120, Silverstone Tejim TJ05 (this case arrive yesterday - it's so so nice), 120mm acousticfans all round etc. etc.)
    Not too interested in the brand thing - I've built machines with both boards with no problems
    What are peoples experience with these boards :confused:
    Are their any other alternatives (passive chipset cooling is a must) :lease:
  2. Nitesh9999
    Nitesh9999
    Aug 31, 2005
    67
    Manchester, UK
    +3
    I have no experience of your suggestions, but the Asus A8N SLI Premium has a passively cooled chipset too.
    I used to have the Asus A8N Sli Deluxe (moved to the DFI SLI-DR for overclocking reasons). And its a cracking stable board. Very easy to setup and a brilliant manual. The premium is even better. So I would recommend it!!
    Nitesh
  3. OneEleven
    OneEleven
    Oooo I'll give that a look - I've used a few DFI LanParty baords in teh past and have been most impressed.
  4. Nitesh9999
    Nitesh9999
    Aug 31, 2005
    67
    Manchester, UK
    +3
    Sorry, i wasn't clear,
    The DFI is what I use now, it ISN'T Passively cooled :thumbsdow
    The Asus A8N Sli Premium is the board that is passively cooled.
    Link
    http://usa.asus.com/products/mb/socket939/a8nsli-p/overview.htm
    I used to own the deluxe version of that baord (not passive) and it was great, so I can only assume the Premium is better, the reviews have been good :smashin:
    Hope that clears things up.
    Nitesh
  5. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,127
    +1,169
    I too have the Asus A8N Delux - would recommend the Premiun (wish I'd bought it). It can switch SLi modes on the fly as well
  6. Embarker
    Embarker
    Apr 19, 2004
    1,676
    Garden of England
    +70
    Or just stick a zalman NF4 cooler on the cheaper asus A8n-Deluxe like I did.
  7. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,127
    +1,169
    Indeed. I'm going for a Zalman NB47J. But the premium is only £13 more than the delux, and buy the time you've bought a cooler (not in stock everywhere, and rip off £15.56 at overclock. £9 at overcloers, and not in stock) the difference would be minimal, and the premium wouldn't require you to have to add a cooler, AND you can switch SLi modes without opening the PC up.
    If you want a quiet board, and think you may ever use SLi, I wouldn't by the Delux (which is what I bought - doh).
  8. OneEleven
    OneEleven
    Won't be using SLI - graphics will either be a 6600GT passive ox X800-XL passive
  9. stlic
    stlic
    Feb 17, 2004
    762
    +19
    Save yourself £40 and get a possible new champion http://www.anandtech.com/mb/showdoc.aspx?i=2524. A fantastic board for the price. Not really for hardcore overclockers unless you have a sweet chip but otherwise I would have bought that board over my AN8 in a heart beat if it was out a few weeks back. Oh yeah did I mention it can use you existing AGP card until your ready for PCI-Express. Also PCI_Express performance is exceptional.
