So which 32 " is it
Discussion in 'General TV Discussions Forum' started by sambullet, Jul 12, 2002.
  1. sambullet
    sambullet
    We've heard it all now. PL10 and PL1 have line and blotches. Phillips have geometry problems, JVC FT1 and the T25 have lines through them.
    Is there one TV out there for the same sort of price that I can buy with some confidence? Any suggestions to anyone who has there regrets. There must be one 32 " Widescreen TV that beats the rest for the price???????
    Cheers lads
  2. DavidT
    DavidT
    Oct 30, 2001
    2,490
    +257
    There is..... Philips 32PW6515.
    I have had this TV for 5 months and have none of the problems posted on this forum.
  3. Squirrel God
    Squirrel God
  4. ricke
    ricke
    If you read the posts enough, you'll find that:
    a, evey make/model of TV seems to have some sort of problem,
    b. there'll be someone out there who has a "problematic" TV but doesn't have the problems
    I've been wanting to buy a decent 32/36 inch for ages, but whenever I login and read the posts..........it's back to the drawing board......:confused: :confused:
    I think the best thing to do is make a short list, check out the forums for known problems and check out the TVs in the shops. Combination of these should cut down your shortlist and then just go for one you like. Main thing is you should buy from a decent dealer i.e. JL, HOF or a specialist TV dealer, in that way you can send it back with the least amount of hassle (hopefully)
    Now......where's my short list, another one to knock off I think..........
    :D :D :D
