So where is the Signs DTS track?
Discussion in 'Movie Forum' started by frodobaggins, Oct 20, 2003.
  1. frodobaggins
    frodobaggins
    I have the R2 copy of Signs. which has DTS clearly daubed all over the cover. But when played it's always DD, with no sign (groan) of DTS availability at all.
    Anybody have any clues?
  2. popeye
    popeye
    Feb 12, 2002
    779
    19
    Leeds
    Here's what to do!
    Upon loading the disc a lanuage screen will appear. Select the lanuage you require and the main menu screen will be presented. click on the set up option and you will be taken to a further screen with the thx optimizer logo. Select lanuages again. It's on the top left of the picture. You will then get a further screen which gives you the dts option.
    Great soundtrack. Enjoy!
    popeye
  3. frodobaggins
    frodobaggins
    Ah, yes got it, thanks.
    That was so obvious to find, wasn't it?!!
  4. alle v
    alle v
    Nov 11, 2002
    211
    19
    Derbyshire
    ...You could also check to see if your DVD player has an 'audio' button. It should allow scroll through all the audio tracks on the disc whilst it is playing.
  5. rags
    rags
    Apr 13, 2003
    4,086
    London
    +301
    I picked up an exrental copy of Signs from blockbuster which I dont think has the DTS track. Is the DTS version much better that the DD ?
