So Many Choices - Subs
Discussion in 'Subwoofers' started by slay, Sep 24, 2001.
  1. slay
    slay
    Sep 14, 2001
    62
    11
    Cumbria
    +3
    HI Folks, recently got a 40" rp telly and need an active sub to go with it. Only got 150 quid left so choice is fairly limited. Was thinking of PDR10 or Mourdant short MSW 20. Any advice gratefully recieved.
  2. dAvE6
    dAvE6
    um, for that kind of money its a hard thing. but if you can find a cheap paradigm-10 then that would probably do the best in its price range. i did have a yamaha and it wasnt great to be honest. a bit boomy and undefined. to get a really good sub you will need to spend around £500. in fact why dont you wait until you have saved up? its a vital part and you may regret not just waiting and getting an infinitly better one later.
