So many cables, so few holes
Discussion in 'Home Cinema Control & Remote Controls' started by Mr. Flibble, Jul 5, 2003.
  1. Mr. Flibble
    Mr. Flibble
    I'm sure this question has been asked many a time but I couldn't find any answers with a fearch of the forums.
    My problem is that I want to connect 2 decoders and one vcr to one port on a projector. And I want it to be IR controlable. Are there any remote controlable SCART switch boxes - something that could be controlled by a programmable remote (eg, the Pronto)?
    Also, following the advert on these forums I noticed the RGB to VGA or RGB to componant boxes (http://www.rgbtosvideo.com/). Are these any use, whats the benifit of this over getting a RGB scart to VGA cable?
  2. Mr. Flibble
    Mr. Flibble
    I have found the following products that seem to be what I'm looking for: Holdan HSR1000 (www.holdan.co.uk), Trilogy 1(http://www.threedoubleyou.com/quattroscart.htm) and another one which I can't find again :-/
    Has anyone had any experience with either of these? Would both be controllable by a Pronto? Which should I go for!!? :)
  3. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    I have the Holdan. It is a very well built switcher, much more solid than the quintro.
    I have managed to programme the remote for use on my Marantz RC200 MK2.
    The only thing it really lacks is wide screen switching support.
  4. Mr. Flibble
    Mr. Flibble
    Great. Can you choose an input directly with it or do you have to scroll through them untill you reach the one you want?
  5. Mr. Flibble
    Mr. Flibble
    I found the third one I was looking at earlier: KEENE Scart Commander (http://www.keene.co.uk/system/keene.htm).
    It is a fair bit more expensive than the Holdan, but I can't see any advantages of it. Am I missing any?
  6. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    While the Holdan won't support WSS it will automaticaly switch to what ever device you power up.
    To select an input manualy you have to scroll through.
  7. Mr. Flibble
    Mr. Flibble
    Ok, thankyou all for the info. I think I'll go with the Holdan.
