So it will be a 50" HD
Discussion in 'Plasma TVs Forum' started by dali1020, Aug 22, 2005.
  1. dali1020
    dali1020
    Jun 26, 2004
    285
    Reading
    +3
    "So it will be a 50" hd plasma !" I`m after all the info i can get from you guys now, reviews, good AV dealers for demo ,best prices, set up details etc Cheers for the help :lease:
  2. Pat Marcus
    Pat Marcus
    Oct 29, 2004
    610
    Ibstock
    +8
    your profile doesnt say where you're from. If you're in the midlands, I can give you sone pointers. Im sure you know what the plasma options are - 50" Panny PV or Pio 505XDE if you want a TV now, Panasonic PHD7, Pio MX or Fujitsu XHA40 if you want a screen instead. If you wait a bit there will be a TV option from Fujitsu and the Pio "6" series will be out, as will the Panny "8" series.
    Every single one of the above is a good screen.
