So i decided to bite the bullet!!
rvdbarnes
howdy!
Last night i couldnt take it any longer, my new black case, complete with cd drive and motherboard was staring at me at i couldnt do it anymore, i whipped my credit card out of the drawer and logged onto overclockers to get more components, decided on:
AMD 64 3500+ VENICE 939skt
2X512mb RAM (crucial, gone for the 2.5 cas in the end)
120GB SATA hard drive
oh, and a floppy drive for good measure
Hope i havent dropped any clangers in my choices? :rolleyes:
rvd
i-bert
I would think 2gb of Ram is a good idea with todays games.Battlefield 2 and F.E.A.R are said to run much better with 2gb.
rvdbarnes
fair comment, i may consider adding 2x512 extra RAM in the future, see how i get on to start with.
thanks for the suggestion.
AML
It might be wiser to start with 2X1gb. But 2X512 is not bad. And you still have space to upgrade to 2 gig or eve 3gig if you add 2 sticks of 1gb.
Darko
Agree I just built a new PC and I put 2+1gig sticks of crucial in that way I am not limited to upgade I still have a few slots left for a few more gig sticks
Darko
wormvortex
the case of fear states it needs 512 and recommends 1gb
I dont like overclockers as they dont include the VAT in the main price so u see something cheap click on it and realise its no cheaper than other sites
AML
What it states on any game box is really just a bare minimum and an average.
Not what it needs to play the games at high settings.
Trust us when we say that 2gb is needed for many new games, and probably in many more from now on.
Darko
If you try and run Battlefield 2 on just 1gig your PC may chew the disc up and spit it out like a cheap whore I would imagine fear will do the same, These new games are ram eaters and most hard core gamers are opting for a 3rd stick of 1gig because even on 2 gig load times are long.
Darko
if its a 2gig machine and load times are sorted by adding another stick .... then whoever owns the machine needs to be shot.
Fear uses up to 900MB ...... leaveing 1.1gig of ram available to the system ... If you used that up then there is some serious problems in the system.
Darko
Nope new pc runs fine but if you want levels to load quicker the answer is more ram besides its not uncommon for gamers to use 3 gigs of ram.
Darko
wormvortex
Darko
my 1gig aint liking all this talk of 3gb being used by gamers, he may be in need of a friend or 2
Darko
Hey bud its cool you can make your own dicision when your PC is up and running, everyone builds there PC to there own spec I personally dont like the long load times of games like BF2 so I have 2 gigs , My PC is 2 weeks old and its all top componants so it runs fine I am just not good at waiting for the little bar at the bottom of the screen and the difference when I went fro 1 to 2 gig was amazing for load times and smooth game play.
But having said that the guy to listen to is Ethics Gradient as he is the senior guy and he will put you right.
Cheers Darko
wormvortex
the loading time on hl2 really got to me espically when u'd walk through a door it would load, u'd start playing forget where u were and walk back through it making it reload the last part then you'd have to walk through it again to advance. So a total of 3 loads, i manged to do that numerous times
Darko
Exactly this is a main factor but as I said it depends on the machine you wanna build if you dont mind loading screens and your clan sitting around waiting for you to join a server its cool, I dont like this.
Ethics Gradient is your man he is pretty clued up and he will put you right just dont let him scare you as he is pretty blunt.
Darko
J
JayList
rvdbarnes said:
howdy!
rvd
I've got the same specs. Got a raptor hard drive which is fast and quiet. And some overlclocked cas 2.5 ram.
Same CPU.
Eveything runs sweet with my IceQ 2 Turbo.
Only got one gig of ram and not really feeling much need to upgrade. I gues s BF2 churns the drive for about 5 seconds at the start but that's it.
Still not convinced PC uses Ram that efficiently for games.
rvdbarnes
cheers for all the replies chaps/chappettes?
I shall inevitably add an extra pair of RAM at some point, id prefer to take up another dual than the single.
Goingm slightly off subject, the 3500 cpu iv just unwrapped,
under the heat sink is like a greasy, grey mesh, around the size of the cpu,
is this instead of me having to put thermal grease on the cpu, or as well as?
rvd
rvd
Darko said:
as Darko says - yup ;)
Its a thermapaste that usually also has some adhesive qualities.
Only older chip generations like the XP etc, it was sometimes better to clean it off and use a high quality product like artic silver - especially if you were going to overclock.
However, the amd64's have a larger top profile to transfere heat, and they also run alot cooler as standard due to the thinner die size / lower voltage requirements ... so the bog standard heatsink and out of the box thermal paste is fine.
Uridium
Are the fans bundled with the retail XP64 chips still as loud as the ones that used to ship with the old AthXP's? or are they supplying quieter ones nowadays?
I still buy OEM chips and pick up a quiet fan/heatsink at the moment but the Retail ones are handy for the 3 year warranty if the fans aren't too loud.
Darko
The Fan def looked different and it has a much better clasp which means no more scrapping the mobo with a screw driver as for if is quieter I would not know as I got so many fans in my tower it hovers off the desk, I had to put a guid rope on it to stop it from hitting the ceiling.
Darko
oxygenuk
:rolleyes: 2gb is not neccesary at all with them games, maybe with games in 2007 yeah, but not now :rolleyes: . atm nowadays u dont need more than 1.25gb max
Latest News
Rumour: Samsung even closer to OLED TVs in 2022?
  • By Andy Bassett
  • Published
Audio-Technica launches ATH-SQ1TW true wireless earphones
  • By Andy Bassett
  • Published
What's new on UK streaming services for December 2021
  • By Andy Bassett
  • Published
Best Projectors of 2021 - Editor's Choice Awards
  • By Steve Withers
  • Published
Black Friday 2021: What you need to know
  • By Andy Bassett
  • Published
