Jester1066
I'm undecided on number, brand etcI only need one![]()
Actually this thread was supposed to help with that
My long game is to go full pre/pro though.
I've recently become without a Power Amp and just have the AVR powering my speakers. While I'm here I thought I'd carry out a little listening test of just using the AVR against the AVR with additional power. The Receiver is a Marantz SR8012 and the Power Amp was a Emotiva XPA.
Once the power Amp was removed I didn't rerun the EQ but did check all the channel levels along with the Subs, just for good measure. The speaker config. wasn't changed and remained as 5.2.4. So just really simple, nothing technical, no measurements, no graphs, just me having a good old demo session. For this one, it's a movie session only, no music.
Up for listening and in no particular order is, Alita: Battle Angel, John Wick 2, Edge Of Tomorrow, Oblivion & Ready Player One. I chose two listening volumes, the first one at -15.0db and the second at -5.0db. I know even -15.0db could be considered loud or even too loud for a lot of people and -5.0db being totally out of the question. But they represent where I do my listening, typically around -10.0db give or take a few.
First up, Oblivion at -15.0db. At this volume level I didn't expect to encounter any particular issues, and I didn't. I don't consider it to be a particularly complex or dynamic track though.
At -5.0db. Even at this level it didn't sound like things were falling apart. It sounded reasonably controlled if slightly livelier which felt like it was presenting more detail. The AVR didn't sound like it was struggling, but it did have a slight edge to it though.
Next up, Alita: Battle Angel at -15.0db. Again at this volume there was no real problem. Plenty of detail and I could watch the complete movie at this level.
At -5.0db. Now this sounded completely nuts at this volume. The sound became harsh and harder on the ears, and it was more difficult to pick out detail amongst the action. No way could I watch the movie at this volume, it was far too bright and edgy.
Next, Ready Player One at -15.0db. I chose the race scene here, you know the one. This was another one that was still presenting the detail but had a slight edge that I'd heard previously. Like it's bordering on being too loud and marginally too uncomfortable for a whole movie.
At -5.0db. Oh my days, turn it down ! Similar to before, the detail becomes lost in the mayhem and it just gets very rowdy and unsustainable for even a short period of time, never mind the whole movie.
Next, John Wick 2 at -15.0db. You got to love those handgun shots. They come across with such frightening force that they almost hurt the viewer. The impact is astonishing and I think this would be plenty loud enough with the AVR on it's own.
At -5.0db. If you don't want a sore head, don't listen to this at -5.0db as those handgun shots will rip clean through your skull. The shotguns are crazy enough but the handguns are so intense that you could quite likely raise a couple of inches out of the seat, as I did. The scene was in the night club and JW is on the stage and he fires a shot before jumping off and venturing into the caverns. It's head splitting and totally uncomfortable but quite an experience. I warn you not do it !
Next, Ready Player One at -15.0db. OK, I didn't get to attempt this one after my experience with JW 2, I needed time to recover my senses. My head was still a little shell shocked, quite literally. But I dont think I would have experienced anything differently to what I'd heard previously, so it's probably not that much of a loss.
So after all that, I think around -15.0 db is probably the limit. And even then it really depends on what you are listening to and the quality of the mix etc. Jumping the volume from there and I know -5.0 is crazy loud but things to start to break up. It just sounds really loud, losing detail and control with the dynamics running wild and edgy. A bit like an Orchestra without their Conductor. With the Power Amp in play I didn't experience any of these things. I could raise the volume to -5.0db and still pick out detail without the edgy harshness. The sound remained a lot smoother and more sustainable over a period of time.
I haven't replaced the Power Amp yet and so could do another set of demo's now that i've recovered![]()
I'm currently running 7.1.4 from my Denon 4400, with a smaller 2 ch amp for two surrounds.
Room is fairly small (about 3.5m wide by 3.8m long).
I listen about -10db for films, but above that it can sound quite harsh and overly bright. Speakers, with exception of a pair of monitor audio inwall surrounds, are all M&K - fronts are M&K IW150. My gut is that a power amp, even for the LCR would help this, although I don't have a huge amount of absorption, so that is another one to look at.
Used Audyssey and then tweaked it under the guidance of @mb3195 to reduce the top end. It's definitely better but I think running 9 channels from the Denon at full tilt is just asking too much. It would be inline with what @DodgeTheViper has posted above.
It was an extreme test tbf. I’m glad I’ll have an amp back in this week though.Used Audyssey and then tweaked it under the guidance of @mb3195 to reduce the top end. It's definitely better but I think running 9 channels from the Denon at full tilt is just asking too much. It would be inline with what @DodgeTheViper has posted above.
Based on what I've read, if the room is untreated I suspect this harshness will have a lot to do with the increased reverberation/decay time you will get at higher listening levels. I've haven't done it yet myself but I think you can use REW to measure the RT60 (i.e. time to decay to 60dB) across the frequency range which can help identify this issue and point you towards the right acoustic treatment.I listen about -10db for films, but above that it can sound quite harsh and overly bright. Speakers, with exception of a pair of monitor audio inwall surrounds, are all M&K - fronts are M&K IW150. My gut is that a power amp, even for the LCR would help this, although I don't have a huge amount of absorption, so that is another one to look at.
There’s an important difference here though. Your B&W HTM62 centre has 85dB sensitivity so requires about 3.2x the amount of power that Harkon’s 90dB centre does to do the same thing. If an AVR’s baulking at outputting up to 4 or 5 watts per channel then there’s probably something wrong with it.I have the same Receiver powering 9 channels, slightly larger room and had exactly the same issue although with B&W's. To be fair sounded harsh before -10db.
Front LCR now powered with Emotiva BasX A3.
Today ran Atmos Demo Amaze and Leaf for the Father in Law at -5db. No signs of harshness and no brittle sounding treble.
Then later on get good amp for LCR.say xpa 3
Re. the power situation, the IW150s have 90dB sensitivity so at -10dB volume in a room that size they should only be pulling a few watts each on the loudest 20dB peaks. A tell-tale sign of high in-room speaker efficiency at the MLP would be if you have to use very negative speaker trim levels (say -12dB to -8dB) in the AVR in order to calibrate 0dB volume to output 75dB on the internal test tones.
Surely the size of the room shouldn’t affect the power needed to reach -10db? Probably showing my ignorance here…
So, are you saying that I shouldn’t need a power amp and that the Denon should be able to drive these to higher levels without issue?
No more than the equivalent of four channels are FULLY driven at any point by a movie soundtrack. THX don’t even stress test more than 5 channels in their amplifier certification process for this reason. 5 channels driven on X4xxx series is 88W. 140W gives 2dB more output than this, that's all.How many living room systems require 300W RMS per channel?
If we consider 9 channels being driven on a X4*** series can have per channel output dropping into the 60's with constrained dynamics (7 channels driven measured at 76W)
The the BasX A3 at 140W all channels driven is a significant upgrade on the Denon's internal amps.
Room size affects it due to extra distance to listener plus the amount of boundary gain you get. In an untreated <3,000Ft3 room boundary gain can add 6dB to the output as we hear twice the amount of sound from reflections than we do directly from the speaker.Surely the size of the room shouldn’t affect the power needed to reach -10db? Probably showing my ignorance here…
Xpa 3 for front three
Then bas-x or Nord 125w X 8
Yes the bas X is upgrade on a avr, but amps like ATO 1803 are upgrade over bas X. Two big power supplies, and 18,000uf per channel dedicated storage.
Or get three monoblocs in my avatar for even bigger upgrade
In a USA basement Home Cinema build perhaps.
In a UK 5m x 3m living room why spend the extra if there's absolutely no need for the extra power in the system?
As Mr Wolf kindly explains.
Are we perhaps looking at more than just watts?
How do we measure the ability of a Receiver to deliver dynamics with the relatively small power supply and the usual absence of significant capacitor capacity?
It's a very good point and the answer to this explains why a 30W/channel stereo audiophile amp can sound so much better than a 150W/channel flagship AVR or a 300W HT power amp when playing music.Are we perhaps looking at more than just watts?
