So confussed?
Discussion in 'Microsoft Windows' started by Rhydem, Sep 19, 2007.
  1. Rhydem
    Rhydem
    Aug 9, 2006
    1,619
    48
    +39
    Which version should i use
    64x bit or x86 (32 bit)
    My PC spec off head is:
    Intel Core Duo 2
    1gb Ram
    250GB
  2. echrada
    echrada
    Jul 8, 2006
    3,159
    103
    +314
    Go for the 64x as you will have more options.
  3. treacle
    treacle
    May 17, 2006
    598
    +16
    32 BIT is the one for the present, less compatibility problems.
    With your setup you won't see any difference.
  4. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    I'd go for x84, 64-bit support is virtually non-existent. Well I mean you may find the odd driver, but nothing like the support you get for x86.
