wallace4793
I have a hitachi 42pd7200 plasma which is quite a high spec in the range. I use a digital satelite to recieve my channels (sky).
On occasions the picture i recieve is awash with snow like an poor analogue signal. I know it isnt my satelite picture as it is fine if i change the channel or put the menu on. It seems to be on certain broadcasts on certain channels. for example C.S.I on living is sometimes especially bad and sometimes ok, eastenders is another that it seems to affect. Has anyone come across this before?
thanks john
thanks john
