snowboarding and skateboarding
thekid17
looking for a video camera for what the tiltle says plus wildlife.
ive been looking at the canon gl2 and the sony DCR-VX2100.
any reviews and personal adivice on these and open for suggestions on other video cameras
thanks
rjmehra
The most important thing we need to know before giving any advice is BUDGET?
You can film all those things with a Flip camera which are cheap all the way up to crazy things I'm scared of mentioning.
A rough range is a good idea, say £100-300, £300-600, £600-1000, £1000-£3000, etc...
best
-R
rjmehra
ah!
In that case there is only ONE option I would consider.
The Panasonic HMC40 (HMC41 in Europe)
Learn about Panasonic's AG-HMC40
I have the bigger brother HMC151 (HMC150 in the US) and cannot rave about it enough for this sort of thing. Also Panasonic has the best warranty package by far. (Five years free return to base, repair, replace if necessary!)
-R
rogs
Don't forget that the AG HMC 40 uses CMOS sensors, while the AG HMC151 uses CCDs.
The HMC40 will use a CMOS Rolling Shutter, which can cause problems in situations where high speed vibrations -or high speed pans - are likely to be used.
Like snowboarding and skateboarding, for example!
May not be a problem, but something to be considered when looking for a decent camera, for a specific task.
