Snow question
Discussion in 'Satellite TV, Sky TV & FreeSat' started by cuewoz1, Nov 18, 2004.
  1. cuewoz1
    cuewoz1
    Oct 30, 2003
    187
    As you probably know snow stops the signal to the satellite dish, and I was wondering if there is any way you can apply anything to the dish to stop snow settling on it?
    I always stick my mop out of the window to get it off, but am not always in to do this.
    cuewoz
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    I have my wife stand over it with an umbrella if there's an important footy match on ;)
  3. miniman
    miniman
    Apr 14, 2003
    567
    Birmingham
    +7
    :D :rotfl: Nice one just told my wife i'm going to buy her an umbrella.
  4. Garrett
    Garrett
    Apr 21, 2001
    32,312
    2
    167
    The best thief you’ll never see.
    +4,216
    Isn’t there some stuff you can spray on that’s water repellent? I coated mine with waxoil. And never had any trouble with snow or rust.
  5. cuewoz1
    cuewoz1
    Oct 30, 2003
    187
    Thanks for the tip Garrett.
    Where do you buy this from? is it available at DIY shops like B&Q?
  6. miniman
    miniman
    Apr 14, 2003
    567
    Birmingham
    +7
    Try halfords as it is used to rust proof cars. Mark
