Snazio software problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by WSH, Mar 23, 2006.
  1. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    When I start the net cinema server software up it says "SNC services could not start up". I can see the pc name on the tv and have connected via cat5.
    I've tried the latest software from the internet and the one that came on the disc to no avail.
    Anyone know how to resolve this?
  2. Hi-Jack
    Hi-Jack
    Are you using any other streaming software?
    It could be the port is busy due to other software.
    If you are using winXP, shut down firewall.
  3. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    I had the pinnicle software on previously, uninstalled and removed everything referring to pinnicle in the registry and deleted the pinnicle folder in program files in safe mode.
    Tried with firewall off and no luck.
    and rolled back to a previous restore point. Going through a Linksys router. Vone server enabled in windows firewall. The pinnicle server software worked fine on the showcentre.
    [​IMG]
  4. Hi-Jack
    Hi-Jack
    Check the services in Control panel and see rather pinneacle software has
    left something running. I have heard before there are issues between Snazio
    and pinneacle when it comes down to combining or swapping them...
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Also check the System Event Log to see if there are any entries in there that are relevant .. of course, they're often pretty cryptic so you may no glean any useflu info even if there are.
  6. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    I've given up with the Snazio software. I'm running Swiss center, windows media connect and the Pinnicle software on it and will probably decide to keep swiss centre although the Pinnicle has a memory of the % of video watched so I can jump to where I left off but takes up more resources.
    Am I missing anything not running the Snazio software?
    One other question is why when I fast forward or rewind some files I see the picture changing whereas with others I can't? For example I can with Lost but cant with 24. They are both 700MB HR.HDTV files.
