snake!!!
Discussion in 'Home Cinema Control & Remote Controls' started by richard plumb, Jan 19, 2004.
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    I have what can only be described as either a little snake, or a fractal, in the centre of my pronto screen, about 1cm square. Its gotten slightly larger recently, so I'm getting a bit concerned.
    It is visible at all times, even when the screen and backlight are off.
    Is this something to do with the LCD? Is it leaking or something? Its an old RU890 (European)
  2. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    What happens if you position a button/graphic over it?
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    it appears over everything. It is also a slightly different colour to the buttons - almost a very dark green.
  4. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    Certainly sounds faulty, how old is it? Have you tried taking the batteries out, is it still visible? If it is then it sounds like you'll be needing a new screen unless you can live with it? If not try re-setting back to factory default and see if that does anything!
    And if all else fails drop Philips a line and see if they have an answer..
  5. thedoc
    thedoc
    Aug 22, 2003
    262
    16
    I think this is a break down in the crystalline substrate used in the screen. IIRC it doesn't affect function but is more a cosmetic problem. Only way to fix is either a new screen or new pronto ... I don't know if you can still obtain new screens anymore.
