Ken
Established Member
Could someone enlighten me; are smooth pans on a 60hz display possible, with PAL movies?
Ken said:Could someone enlighten me; are smooth pans on a 60hz display possible, with PAL movies?
That's what I was saying, which is why setting to around 50 is needed, I had to set mine to 50.039 due to inaccuracies in the card's clock generator. The problem is video frame-rate related.Ken said:unfortunately it is the only frequency that it will sync at. As PAL is 25 fps and the refresh 60hz they are not divisable, so doesn't this mean syncing them is going to be a problem without some sort of intervention?
Ken said:Why is it that manufacturers sell 60hz displays in a part of the world that is all 50hz?
Ken
