Smell of burning on sony dvd
Discussion in 'Blu-ray & DVD Players & Recorders' started by merlynn, May 23, 2003.
  1. merlynn
    merlynn
    I seem to get a faint burning smell when using my Sony Dvd player i wonder if anybody else has experienced the same problem it does not appear to cause any other problems .
  2. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    I have heard reports of Sony players generally overheating, ie cooking discs, but a burning smell sure isn't good.
    I would phone customer service of the shop or maybe email sony and see if they have had any similar problems
  3. billduff
    billduff
    Mar 17, 2002
    275
    16
    Just to the right of civilisation
    Doesn't sound good. electronics really should not smell of burning. :eek: :eek:
    Is it in a dusty environment ??. It may just be a build up of dust getting heated. Take it out and give it good dusting.
    Is it getting too hot ??. After its been on a while check the case for 'hot spots'. Make sure its in a ventilated area and not sitting right on top of your amp etc.
    I have a Toshiba DVD player and it kicks out very little heat but I would imagine that they will be about the same, there is not much in the way of high-power using components in a DVD player.
    If there are any hot spots get it checked out (or replaceed if it is under warranty).
    Hope this helps
  4. Squirrel God
    Squirrel God
    It may not cause other problems, but as said above, get it checked out. I would stop using it and unplug it from the mains in the meantime. The last thing you want is it starting a house fire :eek:
  5. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,694
    In a secret location with Jennifer Lawrence
    +7,478
    Moved to DVD players forum
    Greg
