Quantcast
smearing,sony kp53s4u rear projection
R
robbyamanda
can anybody help i have a smearing problem,mainly red but also other colours ,i have read the post for the kp44px2,i cant get into the service mode and i have shadow efect on faces, this more so in dark scenes, hope you can help. or should i just set fire to it ? :lease:
ayubars
make sure ypu press the right button. I couldn't get into service mode either but then realised i was presseing the wrong button
R
robbyamanda
could you clarifie is it the arrow button you press or i ,i dont have an i button on my remote,if you press 1 button first it goes to channel 1 ,i must be thick
ayubars
Hold on, I'll find out.
I know i found it on the Forum somewhere.
ayubars
As to getting in to the service menu, the usual error is pressing the wrong last button
Press i+ 5 VOL+ [] The final one is the teletext off button
Similar threads
