Smearing, Mixing on Photos.
Discussion in 'Photography Forums' started by ELV, Dec 17, 2004.
  1. ELV
    ELV
    Jun 5, 2001
    690
    Up in the proper north
    +11
    Hello All,
    Iv'e got a problem with my prints on my Epsom photo 830, it seems as though the ink is'nt drying quick enough and its not drying on the page correctly, the effect is simillar to using a felt tip on glass although not as pronounced, it seems to happen with photo papaer only not matte paper,the ink cartridges are JET TEC, iv'e had the problem a while and it used to print just fine with other compatibles, has anone else had a problem simillar and what is the problem, the inks( which i suspect) or the printer and can anyone recommend a good compatible as the epsom ones are rather expensive,apologies in advance if it's the wrong forum but i can't find any other , and iv'e always had good advice here anyhow :thumbsup:
