SMASUNG UE46F6500 or ue46f7000 ???????
Discussion in 'What Is The Best TV For You?' started by shakeel, Jan 31, 2014.
  1. shakeel
    shakeel
    Dec 29, 2013
    5
    4
    HI
    I am in two minds as to which TV to buy. I know specs wise the F7000 is a lot better but I am not sure if it is worth paying £300 more for it?
    the f7000 has 800HZ refresh rate which is double. has a quad core processor ( 6500 a dual core) and also a camera.
    I enjoy playing games and watching movies.
    would the 3D and normal picture quality make a big difference between the two TV's
  2. TyneBridges
    TyneBridges
    Jan 27, 2007
    145
    Gateshead
    +9
    Hard to know without seeing them side by side, but I doubt whether there is £300 worth of difference. We have just bought a UE46F6500 and, so far, are very happy with it.
  3. Scooby2000
    Scooby2000
    Jan 9, 2010
    15,549
    Cambridge
    +2,469
    Have you looked at the Sonys? Very low lag for gaming and the w9 is great for movies.
  4. shakeel
    shakeel
    Dec 29, 2013
    5
    4
    i decided to go for the 6500 as it was in my budget. so far i am very happy with it.
    i bought t5he sony w8 and was very dissappoint with it. thought it was a waste as the 3d and sd quality were very bad.
    i have a bit of a query with my 6500 my advanced settings are always greyed out not sure how i can change that?
    thanks
