Smasung LE26R41BDX Questions :)
Discussion in 'LCD & LED LCD TVs Forum' started by hannay, Sep 5, 2005.
Tags:
  1. hannay
    hannay
    Jul 4, 2002
    93
    Isle of Man
    2 questions regarding this suberb tv...
    1 - What is the best cable for connecting my Xbox? Sames goes for sky+ I suppose?
    2 - Anyone know the code for controlling the TV through a Sky+ remote? the standard samsung 0060 does not work.
    thanks
  2. hannay
    hannay
    Jul 4, 2002
    93
    Isle of Man
    anyone? :)
  3. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    1= Component
    2= Dont know, dont like using the Sky remote for my TV...If you browse the net I'm sure you will find the right code.
  4. hannay
    hannay
    Jul 4, 2002
    93
    Isle of Man
    is there a particular component cable worth getting?
  5. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Well it has to be the Xbox specific HD AV cable. There are third party ones but it would be best to stick with the official one.
    Xbox High Definition Av pack
  6. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    I'm certain I saw someone post the remote code in a thread yesterday - worth a search.....
  7. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    The Xbox HD AV pack has five RCA connectors on it, and comes with interconnects; so you can replace them if you want to.
    Should definitely buy the official pack though, and the included cables are good enough.
  8. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    That's the one I have, the official one although I can't make use of it right now as I don't have a TV with component inputs yet. I'm planning on buying a second TV probably the Samsung LE26R41BD so I can use it with that.
  9. multiply
    multiply
    Sep 7, 2004
    312
    Surrey
    +9
    Remote code 646
